wanted throwout bearing hydraulic line #1346211
12/04/12 11:50 PM
12/04/12 11:50 PM
qc
mxbeep Offline OP
mxbeep  Offline OP
qc
i need to purchase a flexible hydraulic line for my Keisler throwout bearing. Keisler only supplies a hard line from the bearing out which is converted to a flexible line. I tried calling them and they cannot help.
Im looking for a source that could fabricate a flexible line from my Wilwood master cylinder to the FTE (keislers supplier) throwout bearing.
Re: wanted throwout bearing hydraulic line [Re: mxbeep] #1346212
12/04/12 11:59 PM
12/04/12 11:59 PM
IN
ahy Offline
ahy  Offline
IN
In line tube can generally fab whatever you need. I had some custom brake lines done by them. I mocked it up by cutting the correct ends off lines that didn't fit and joining them with a correct length of fuel hose and clamps. I sent the mock up in and they sent matching brake lines back. Fit was perfect.
Re: wanted throwout bearing hydraulic line [Re: mxbeep] #1346213
12/05/12 12:22 AM
12/05/12 12:22 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Any parts store that makes HYD, lines can make what you need, just supply the thread size, line length, etc...you could also go to McMaster Carr com, they can supply just about any line you need, made to your specs
Mike
Re: wanted throwout bearing hydraulic line [Re: DAYCLONA] #1346214
12/05/12 12:38 AM
12/05/12 12:38 AM
qc
mxbeep Offline OP
mxbeep  Offline OP
qc
Mike
thanks Mike, but i tried 2 local hydraulic shops and both couldnt get the end lines.
Re: wanted throwout bearing hydraulic line [Re: mxbeep] #1346215
12/05/12 01:25 AM
12/05/12 01:25 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
What type of fitting is on the throw out bearing?
Why not just get AN adapter fittings for it and the master cylinder then it is as simple as getting some AN lines made up... (The master cylinder side will be simple, just not sure what the bearing end looks like?)
Re: wanted throwout bearing hydraulic line [Re: mxbeep] #1346216
12/05/12 11:17 AM
12/05/12 11:17 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
My hydraulic bearings, including Keisler, came with braided flex lines which I then hard lined to my M/C.
That aside, making braided flex lines using AN fittings is easy. Just Google it.
Re: wanted throwout bearing hydraulic line [Re: OzHemi] #1346217
12/05/12 06:18 PM
12/05/12 06:18 PM
qc
mxbeep Offline OP
mxbeep  Offline OP
qc
throwout requires 12-1.0 bubble flare with a 90deg, Wilwood master cylinder requires 3/8-24 inverted flare with a 90deg. Adding AN adapters will cause clearance problems.
I called inline tube and they cannot help me, as well as lots of internet searching
Re: wanted throwout bearing hydraulic line [Re: mxbeep] #1346218
12/05/12 08:02 PM
12/05/12 08:02 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
On the throw out side...could you use one of these..
http://www.anplumbing.com/search/index?search_text=305-03M121
and use an AN hose with a 90 degree fitting on the end? (Or no room for that even?)
There is a really good local hose place here that would be able to whip you something up I bet, TMR in the city of Orange...just not sure if they do mail order or not? Might be a worth a call to them if you have no other luck else where at least.
Re: wanted throwout bearing hydraulic line [Re: OzHemi] #1346219
12/05/12 09:52 PM
12/05/12 09:52 PM
qc
mxbeep Offline OP
mxbeep  Offline OP
qc
after some figuring out, i think i will be purchasing banjo bolts with AN fitting ends.
thanks to all
