Oil pan bolts- stock length with windage tray? #1344816
12/02/12 12:28 AM
12/02/12 12:28 AM
South Coast of Oregon
dweller Offline OP
dweller  Offline OP
The stock non-windage tray oil pan bolts look to be too short for use with a tray. Do folks go to longer bolts when adding a tray?
Re: Oil pan bolts- stock length with windage tray? [Re: dweller] #1344817
12/02/12 08:15 PM
12/02/12 08:15 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I have always just used the stockers .... never a problem.
Re: Oil pan bolts- stock length with windage tray? [Re: dweller] #1344818
12/03/12 12:36 AM
12/03/12 12:36 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have used these ones before and they worked very well
http://chucker54.stores.yahoo.net/mopenstanset.html
Gus
64 Plymouth Savoy
Dana 60
Re: Oil pan bolts- stock length with windage tray? [Re: dweller] #1344819
12/03/12 01:45 AM
12/03/12 01:45 AM
California
BigDaddy440 Online content
BigDaddy440  Online Content
California
Not sure if it needs to be stock looking, but consider studs if you can. Alignment of tray and gasket is easier, and I think the clamping force of a nut is better too.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Oil pan bolts- stock length with windage tray? [Re: BigDaddy440] #1344820
12/03/12 02:01 AM
12/03/12 02:01 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Ditto on studs, they are .18 a piece at a local industrial fastener supply house. Only bad thing about them is that you can't slide the pan back to clear the K member on a SB once you get the nuts off.
Re: Oil pan bolts- stock length with windage tray? [Re: dweller] #1344821
12/03/12 08:18 AM
12/03/12 08:18 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I've never taken the time to compare pan bolts from an HP engine with the tray to a standard engine without. But I have always had to use longer bolts retrofitting a tray on a standard motor. The stockers just don't seem to make it.
Re: Oil pan bolts- stock length with windage tray? [Re: 6PakBee] #1344822
12/04/12 11:55 PM
12/04/12 11:55 PM
dweller Offline OP
dweller  Offline OP
Thanks for the responses.
Re: Oil pan bolts- stock length with windage tray? [Re: 6PakBee] #1344823
12/05/12 11:54 AM
12/05/12 11:54 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
never noticed a difference in pan bolt lengths , now I need to look in the parts manual to see if there is a difference ???
