Oil pan bolts- stock length with windage tray? #1344816
12/02/12 12:28 AM
12/02/12 12:28 AM
South Coast of Oregon
dweller Offline OP
dweller  Offline OP
The stock non-windage tray oil pan bolts look to be too short for use with a tray. Do folks go to longer bolts when adding a tray?
Re: Oil pan bolts- stock length with windage tray? [Re: dweller] #1344817
12/02/12 08:15 PM
12/02/12 08:15 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I have always just used the stockers .... never a problem.
Re: Oil pan bolts- stock length with windage tray? [Re: dweller] #1344818
12/03/12 12:36 AM
12/03/12 12:36 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have used these ones before and they worked very well
http://chucker54.stores.yahoo.net/mopenstanset.html
Gus
64 Plymouth Savoy
Dana 60
Re: Oil pan bolts- stock length with windage tray? [Re: dweller] #1344819
12/03/12 01:45 AM
12/03/12 01:45 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
Not sure if it needs to be stock looking, but consider studs if you can. Alignment of tray and gasket is easier, and I think the clamping force of a nut is better too.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Oil pan bolts- stock length with windage tray? [Re: BigDaddy440] #1344820
12/03/12 02:01 AM
12/03/12 02:01 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Ditto on studs, they are .18 a piece at a local industrial fastener supply house. Only bad thing about them is that you can't slide the pan back to clear the K member on a SB once you get the nuts off.
Re: Oil pan bolts- stock length with windage tray? [Re: dweller] #1344821
12/03/12 08:18 AM
12/03/12 08:18 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I've never taken the time to compare pan bolts from an HP engine with the tray to a standard engine without. But I have always had to use longer bolts retrofitting a tray on a standard motor. The stockers just don't seem to make it.
Re: Oil pan bolts- stock length with windage tray? [Re: 6PakBee] #1344822
12/04/12 11:55 PM
12/04/12 11:55 PM
dweller Offline OP
dweller  Offline OP
Thanks for the responses.
Re: Oil pan bolts- stock length with windage tray? [Re: 6PakBee] #1344823
12/05/12 11:54 AM
12/05/12 11:54 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
never noticed a difference in pan bolt lengths , now I need to look in the parts manual to see if there is a difference ???
