Oil Pan question #1342746
11/28/12 08:44 PM
11/28/12 08:44 PM
Brea, Ca
Dart Racer Offline OP
Brea, Ca
Anybody use the 31460 7" Milodon pan?
My question is that on their website it says "you may have to shut off motor on deacceleration" and I'm wondering if anyone experienced that, or found it to be necessary.
I need a shorter pan on my car and looking for options.
Re: Oil Pan question [Re: Dart Racer] #1342747
11/29/12 01:52 AM
11/29/12 01:52 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Never heard of that before and I think I`d run away from that deal..................
Re: Oil Pan question [Re: Thumperdart] #1342748
11/29/12 01:59 AM
11/29/12 01:59 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
the way that pan is wedge shaped in the front,when on the brakes the oil can slosh to the front & uncover the pick up
Re: Oil Pan question [Re: Dart Racer] #1342749
11/29/12 03:51 AM
11/29/12 03:51 AM
Is that the one that is seven inches deep center sump and wider on the bottom than up five inches from the bottom? If so I know several racers up here that use it with no problems
Re: Oil Pan question [Re: Dart Racer] #1342750
11/29/12 10:44 AM
11/29/12 10:44 AM
gregsdart Offline
gregsdart  Offline
That comment is meant to cover their butts. Even the best 10 qt systems will have problems if not equipped with trays or scrapers and you stand on the brakes. An accumulator system or crank scraper will reduce or eliminate that problem if you experience it. The crank scraper made a significant change for the better on my deal.
Re: Oil Pan question [Re: Cab_Burge] #1342751
11/29/12 04:54 PM
11/29/12 04:54 PM
Brea, Ca
Brea, Ca
Cab; Not sure as I am just looking at it on their website and picture is hard to tell. Doesn't look like it flares at the bottom.
Re: Oil Pan question [Re: gregsdart] #1342752
11/29/12 04:56 PM
11/29/12 04:56 PM
Brea, Ca
Brea, Ca
Thanks for the input Greg!! The accumulator sounds like a plan if there is an issue.
