Re: Oil Pan question
[Re: Thumperdart]
#1342748
11/29/12 01:59 AM
11/29/12 01:59 AM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
the way that pan is wedge shaped in the front,when on the brakes the oil can slosh to the front & uncover the pick up
[Re: Dart Racer]
#1342750
11/29/12 10:44 AM
11/29/12 10:44 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
That comment is meant to cover their butts. Even the best 10 qt systems will have problems if not equipped with trays or scrapers and you stand on the brakes. An accumulator system or crank scraper will reduce or eliminate that problem if you experience it. The crank scraper made a significant change for the better on my deal.
[Re: Cab_Burge]
#1342751
11/29/12 04:54 PM
11/29/12 04:54 PM
Posts: 570 Brea, Ca
Dart Racer
Brea, Ca
Is that the one that is seven inches deep center sump and wider on the bottom than up five inches from the bottom? If so I know several racers up here that use it with no problems
Cab; Not sure as I am just looking at it on their website and picture is hard to tell. Doesn't look like it flares at the bottom.
