Re: Biondo Terminator Trans-Brake Button
[Re: VernMotor]
#1341755
11/26/12 05:08 PM
11/26/12 05:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Is this the only adjustable button made ?
Biondo makes 2 adjustable buttons... I use the one that is suppose to adjust .03 but I only see about 1/2 of that
[Re: VernMotor]
#1341757
11/26/12 05:16 PM
11/26/12 05:16 PM
Posts: 766 Ohio
Dan Brewer
Ohio
[Re: domingo]
#1341762
11/26/12 08:00 PM
11/26/12 08:00 PM
Triple Threat
Renton Washington
The long throw buttons that are being discussed close slower, and slow down your reaction time. El cheapo buttons, are probably faster, and less consistent.
When reacting off the third amber, many people with fast cars have problems red lighting. Thats what these are for a longer adjustable button to slow down reaction times.
[Re: CHAPPER]
#1341766
11/26/12 09:51 PM
11/26/12 09:51 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
So from what I read you can not ajust the reactor. Is that right ?
Here's a button for ya' Vern,, I see a LOOONNG season for you next year!!
Ya think LOL
[Re: CHAPPER]
#1341768
11/26/12 10:17 PM
11/26/12 10:17 PM
Posts: 2,151 Fancy Farm Ky
wyoming
Fancy Farm Ky
So are both of you old hound dogs are what? Yes the reactor button can be adjusted also, not as much as most of the long throw buttons. But enough for me anyway. The thing I liked mostly about it was the built in stop, you'll understand if you look at there web site, and it mounted where I wanted it. I'm an old enough hound dog that I still use the push buttons on the left side, and I couldnt put up with the steering wheel mount, didnt like dealing with the cords. So I have the reactor mounted on the dash hanging out to where I can reach with my forefigner with my right hand on the wheel, I just slide my finger back, away she goes. But not using it now much, since moving to WV I'm trying to run mostly NSS which doesnt alow the use of a transbrake anyway. Anyway you go though, if I was buying a button it would adjustable. When I first went to a transbrake without one, I was red way to much without one, of course I can go red on the old footbrake also. Proved that more than a few times.
[Re: VernMotor]
#1341770
11/26/12 11:34 PM
11/26/12 11:34 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
She will have no problems controlling it, still has a big block in it, right? Now if you put a small block in it, she might need a third arm to hang on to that beast
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#1341771
11/27/12 12:15 AM
11/27/12 12:15 AM
Posts: 34,884 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I have one on the 67 (Biondo )
Works great , I don't see how you could mount one in a steering wheel, it has a 3 inch throw
I made a bracket, mounted off the dash
The button sits even with the wheel
They dyno the buttons , instructions will tell you how many rings to pull off
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
