Biondo Terminator Trans-Brake Button #1341754
11/26/12 04:59 PM
11/26/12 04:59 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
Is this the only adjustable button made ?
Re: Biondo Terminator Trans-Brake Button [Re: VernMotor] #1341755
11/26/12 05:08 PM
11/26/12 05:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Biondo makes 2 adjustable buttons... I use the one that
is suppose to adjust .03 but I only see about 1/2 of
that
Re: Biondo Terminator Trans-Brake Button [Re: VernMotor] #1341756
11/26/12 05:09 PM
11/26/12 05:09 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
I see Dedenbear makes one. who has used what ?
Dedenbear Adjustable Quick-Release Transbrake Switch
Re: Biondo Terminator Trans-Brake Button [Re: VernMotor] #1341757
11/26/12 05:16 PM
11/26/12 05:16 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
This is a better button than biondo.
http://apexmachining.com/transbrake.html
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Biondo Terminator Trans-Brake Button [Re: Dan Brewer] #1341758
11/26/12 05:51 PM
11/26/12 05:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks just like the Binodo long travel button... I
just dont like the spacers to change it
Re: Biondo Terminator Trans-Brake Button [Re: VernMotor] #1341759
11/26/12 06:26 PM
11/26/12 06:26 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
whats the difference with a regular "el cheapo" button?
Re: Biondo Terminator Trans-Brake Button [Re: domingo] #1341760
11/26/12 07:36 PM
11/26/12 07:36 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Time that it takes the switch contacts to "close", it slows your reaction time.
"Just a Bracket car dressed up like a streetcar"
Re: Biondo Terminator Trans-Brake Button [Re: Just-a-dart] #1341761
11/26/12 07:56 PM
11/26/12 07:56 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
really? why would it be any faster???
Re: Biondo Terminator Trans-Brake Button [Re: domingo] #1341762
11/26/12 08:00 PM
11/26/12 08:00 PM
Renton Washington
Triple Threat Offline
Renton Washington
The long throw buttons that are being discussed close slower, and slow down your reaction time. El cheapo buttons, are probably faster, and less consistent.
When reacting off the third amber, many people with fast cars have problems red lighting. Thats what these are for a longer adjustable button to slow down reaction times.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Biondo Terminator Trans-Brake Button [Re: Triple Threat] #1341763
11/26/12 08:27 PM
11/26/12 08:27 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I think you need to take into consideration where you are going to mount the button, Ive owned a couple and for me the Reactor worked best, I've got a old adjustable long throw button in the shop somewhere, you"d be welcome to try it. It worked fine, I didnt like it on steering wheel, and it didnt fit in to good with pushbuttons as far as locating.
Re: Biondo Terminator Trans-Brake Button [Re: wyoming] #1341764
11/26/12 08:52 PM
11/26/12 08:52 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
So from what I read you can not ajust the reactor. Is that right ?
Re: Biondo Terminator Trans-Brake Button [Re: VernMotor] #1341765
11/26/12 09:31 PM
11/26/12 09:31 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Here's a button for ya' Vern,, I see a LOOONNG season for you next year!!
If you like drag racing, support your local track.
Re: Biondo Terminator Trans-Brake Button [Re: CHAPPER] #1341766
11/26/12 09:51 PM
11/26/12 09:51 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Ya think LOL
Re: Biondo Terminator Trans-Brake Button [Re: VernMotor] #1341767
11/26/12 09:57 PM
11/26/12 09:57 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
You know what they say.."old dogs../..new tricks"..
Re: Biondo Terminator Trans-Brake Button [Re: CHAPPER] #1341768
11/26/12 10:17 PM
11/26/12 10:17 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
So are both of you old hound dogs are what? Yes the reactor button can be adjusted also, not as much as most of the long throw buttons. But enough for me anyway. The thing I liked mostly about it was the built in stop, you'll understand if you look at there web site, and it mounted where I wanted it. I'm an old enough hound dog that I still use the push buttons on the left side, and I couldnt put up with the steering wheel mount, didnt like dealing with the cords. So I have the reactor mounted on the dash hanging out to where I can reach with my forefigner with my right hand on the wheel, I just slide my finger back, away she goes. But not using it now much, since moving to WV I'm trying to run mostly NSS which doesnt alow the use of a transbrake anyway. Anyway you go though, if I was buying a button it would adjustable. When I first went to a transbrake without one, I was red way to much without one, of course I can go red on the old footbrake also. Proved that more than a few times.
Re: Biondo Terminator Trans-Brake Button [Re: wyoming] #1341769
11/26/12 11:01 PM
11/26/12 11:01 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
I check out their site .I just did't see where it said you could adjust it. I really like the design . I think it would be very good for Jenni.. and I do not want to mount it on the steering wheel.But I might have to for her.. she need to have both hands on the steering wheel when it leaves small girl and not sure she can control the car with one hand.
Re: Biondo Terminator Trans-Brake Button [Re: VernMotor] #1341770
11/26/12 11:34 PM
11/26/12 11:34 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
She will have no problems controlling it, still has a big block in it, right?
Now if you put a small block in it, she might need a third arm to hang on to that beast
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Biondo Terminator Trans-Brake Button [Re: B3422W5] #1341771
11/27/12 12:15 AM
11/27/12 12:15 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I have one on the 67 (Biondo )
Works great , I don't see how you could mount one in a steering wheel, it has a 3 inch throw
I made a bracket, mounted off the dash
The button sits even with the wheel
They dyno the buttons , instructions will tell you how many rings to pull off
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Biondo Terminator Trans-Brake Button [Re: bigdad] #1341772
11/27/12 08:16 AM
11/27/12 08:16 AM
tboomer Offline
tboomer  Offline
Vern..I use this one. It is on the steering wheel.
http://www.summitracing.com/parts/ded-pbs-rtd/media/images
Re: Biondo Terminator Trans-Brake Button [Re: tboomer] #1341773
11/27/12 11:50 AM
11/27/12 11:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the short Biondo button on the wheel
