Moving battery to trunk.. how to connect the cables???? #133518
10/07/08 05:09 PM
10/07/08 05:09 PM
Tampa, FL
tpabayflyer Offline OP
Tampa, FL
I bought a cheap summit battery relocation kit and I am wondering how do I connect all the fusible link connectors???? I have 2 seperate ones coming off the original battery positive cable. Do I need to get some kind of solenoid type relay???? What has anyone else done with their mostly street driven car with the battery moved to the back??? TIA TBF
Re: Moving battery to trunk.. how to connect the cables???? [Re: tpabayflyer] #133519
10/07/08 07:38 PM
10/07/08 07:38 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
MAD
Re: Moving battery to trunk.. how to connect the cables [Re: dart4forte] #133520
10/07/08 07:43 PM
10/07/08 07:43 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Here are two that I saved.
Re: Moving battery to trunk.. how to connect the cables???? [Re: tpabayflyer] #133521
10/07/08 09:55 PM
10/07/08 09:55 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Some neat diagrams there.
The important thing to remember is keep it simple.
I'm assuming the kit came with a box, a length of wire and a 2 pin cutoff switch.
nhra rules require that the shutoff be in the positive side, and that when the switch is thrown, all electrical operation will cease(including the running of the car)
Run the big wire from the switch in the back, up to the starter relay. Just like if the battery was still up front. Route your fuse links to the same place they were(I'm assuming on the relay post).
then a short heavy wire from the switch to the plus side of the batt.
Then ground the neg side to the body with a really clean connection, and a heavy wire. You have to have a really good heavy ground on the motor to the body also(unless you plan on running a ground wire up to the motor from the trunk too).
The problem then becomes, if you flip the switch, with it set up like this, it will keep running. The alt still supplies power.
How to stop it? I have found the simplest way is to disconnect the alternator main wire from the alt. Then run a new wire direct from the alt main to the plus side of the battery,( or the same side of the cutoff switch that the battery is on). Then when the switch is thrown, the alt is isolated, WITH the battery, from the rest of the car, and it quits running.
The other plus to doing it this way, , is that you have also bypassed your ammeter at the same time, so that will never strand you again.
No solenoids etc.. needed
I'm sure you;ll get more suggestions
Re: Moving battery to trunk.. how to connect the cables [Re: dave571] #133522
10/07/08 10:19 PM
10/07/08 10:19 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have a short cable from the battery to the cutout switch. Cable runs from there straight to the starter lug, another branches off to the starter relay (4ga or so). Held up fine for 3 years or so, I soldered my terminals onto the cable. Stuck the terminal in a vice, filled it with solder and melted it down with a torch sticking the cable into it while wet. Seems to be fine, no voltage drop issues.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Moving battery to trunk.. how to connect the cables [Re: GoodysGotaCuda] #133523
10/07/08 10:27 PM
10/07/08 10:27 PM
Read carefully what Dave571 posted, and test it this way: Turn off ALL loads, radio, and any solid state (stereo) loads, lights, etc.
Run the car at a good high fast idle, and flip the disconnect off
The car should stop running. If not, you need to change the alternator wiring. There are several ways to do so, but probably the simplest is to run TWO hots to the trunk, a #6 or so from the alternator to the battery, or you can run an extra relay to kill the alternator, or you can buy a 4 post switch and put the small posts in the regulator supply lead.
This is very important. If you should wreck with the engine running for some reason, you want to be able to kill everything
Re: Moving battery to trunk.. how to connect the cables #133524
10/07/08 10:41 PM
10/07/08 10:41 PM
RobX4406 Offline
RobX4406  Offline
Another approach.
I personally like to keep a minimum of potential hot wires to the front.
Re: Moving battery to trunk.. how to connect the cables [Re: RobX4406] #133525
10/07/08 10:49 PM
10/07/08 10:49 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
If its a street car ya really dont gotta worry bout killing the alt power with the shut off. Think about it, if your in an accident who's gonna think to look for a kill switch? I done mine like Goody did. Mounted the battery in the trunk. 1 fat ground cable straight to the frame through the trunk pan. Ran the positive to the front and put it where the normal + cable woulda went and ran a short one off the same relay post to the big starter terminal. Also made a fat ground to go from the block to the frame rail in the front. Works great, never a voltage or charging issue.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Moving battery to trunk.. how to connect the cables [Re: RobX4406] #133526
10/08/08 09:45 AM
10/08/08 09:45 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Rob
Would a relay up front do the same thing as you're diagram? Pick up the feed from the starter relay (main feed), that way when the kill switch is thrown the relay opens and the feed to the alternator is broken. It would charge through the kill switch would be the only difference, plus you only have one wire running to the front.
Where (in the car) did you guys run you're main wire to the front? I've thought about running it up the drivers side along the door sill and through the firewall. This way it's not exposed under the car.
Re: Moving battery to trunk.. how to connect the cables [Re: justinp61] #133527
10/08/08 11:36 AM
10/08/08 11:36 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thats what I did, ran it through the interior. I used a grommet through the firewall that was there (think its for factory clutch linkage?) to keep it isolated. No issues
2020 RAM 1500
Re: Moving battery to trunk.. how to connect the cables [Re: GoodysGotaCuda] #133528
10/08/08 12:58 PM
10/08/08 12:58 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Me too, didnt want it under the cars to get beat and knicked up and cause a problem.
Re: Moving battery to trunk.. how to connect the cables???? [Re: tpabayflyer] #133529
10/08/08 11:10 PM
10/08/08 11:10 PM
Well, I didn't use a cut off switch.
What I ran was some double ott welding cabling wire, with welding disconnects. Ran an 8 guage wire to stater relay.
do yourself a favor, and get yourself a marine style battery box for your battery. Vent it out thru the trunk or something.
Those Hydrogen fumes will rot the metal in the trunk !
Re: Moving battery to trunk.. how to connect the cables [Re: RobX4406] #133530
10/08/08 11:32 PM
10/08/08 11:32 PM
Another approach.
Rob, the way you have that set up, the solenoid is redundant. If you just run the wire you show, IE jumper around the solenoid, and run the alternator "hot" to the battery direct, you don't even need the solenoid
So far as running the cable, I used to run mine the same route as the tail lamp harness, except I believe I ran mine up the pass side.
Re: Moving battery to trunk.. how to connect the cables #133531
10/08/08 11:41 PM
10/08/08 11:41 PM
RobX4406 Offline
RobX4406  Offline
These aren't mine, they are suggestions I've found and on this board over the years.
If you run that line from the alt to the Batt +, it's hot all the time. The relay is there to kill power when the Kill switch is activated. No more hot wires to the front.
Re: Moving battery to trunk.. how to connect the cables [Re: RobX4406] #133532
10/09/08 04:11 AM
10/09/08 04:11 AM
Third Stone from the Sun
Scotts72Rallye Offline
This post would be good for the Tech Archive since so many here move their battery to the trunk.
Scott
Re: Moving battery to trunk.. how to connect the cables [Re: Scotts72Rallye] #133533
10/09/08 06:34 AM
10/09/08 06:34 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
One thing to think about. If you put the battery in the trunk without the master cutoff and take it to the track at all, it will not pass tech inspection. Not even for street test and tune.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Moving battery to trunk.. how to connect the cables [Re: StandOnIt] #133534
10/09/08 09:38 AM
10/09/08 09:38 AM
Tampa, FL
Tampa, FL
Thanks for the info guys... I looked around for one of those borg warner #S605's and can't find a listing for it???
I was not planning on putting a master cutoff in the trunk but maybe I should as will be taking the car to test & tune quite a bit..... I was wondering how you guys spliced into the new + bat cable with 2 fusable links coming off the original + bat cable?? It looks pretty easy to do if I just add the borg warner solenoid if i can find one or something similar... Is a distribution block going to work as well?? TIA TBF
Re: Moving battery to trunk.. how to connect the cables???? [Re: tpabayflyer] #133535
10/09/08 10:42 AM
10/09/08 10:42 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Depends on your goal
If you want to move the battery to the trunk and you are NOT going to the track its much more simple but there are two ways to do it.
1. just running the long cables to the trunk but this leaves you with one long cable which is hot all the time and is a potential fire hazard.
2. if you add a solenoid in the trunk wired to the starter relay that same cable is hot only when the ignition is turned which now eliminates the fire hazard.
If you are doing this for weight transfer and will be going to the track
3 look at the drawing from Mad electrical in dart4forte’s post, its really the only way to wire the car where it will shut off all electrical power from the rear of the car
I went with #2 option, I may end up converting to #3 at some point.
This could be a whole lot simpler if rules would allow for a disconnect switch to be on the negative side of the switch.
GTXKen
Re: Moving battery to trunk.. how to connect the cables???? [Re: tpabayflyer] #133536
10/09/08 10:45 AM
10/09/08 10:45 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I wouldn't do it. There is no real need and it can be a PITA. leave it alone and e'bay the kit.
Re: Moving battery to trunk.. how to connect the cables???? [Re: tpabayflyer] #133537
10/09/08 12:09 PM
10/09/08 12:09 PM
IMGTX Offline
IMGTX  Offline
You need to make the positive battery wire to the front at least two sizes larger than the ground.
If they are the same size and you get a ground in the system they will both heat up like a heating element. If you make the short negative cable in the trunk smaller only it will heat up and reduce the chance of a fire.
I had this happen during a race. The starter came loose and grounded the positive cable. It toasted the negative cable but the positive cable was stone cold. I ran 00 welding cable from front to back and a 4 gauge ground in the trunk. If they had been the same size then the positive wire would have lit up also and been a 20ft burning wire.
If you run a solinoid on the main battery cable to only make the main positive live only while cranking it will eliminate that specific problem once the car is running, but it is still a hazard when cranking.
Don't make the negative smaller make the positive larger.
