Rootsblower w/ alternator and P/S-pump. What options? #1331553
11/06/12 06:33 PM
11/06/12 06:33 PM
The Netherlands
BigBlockMopar Offline OP
The Netherlands
I'm currently building a Roots-blown strokermotor.
It will be mostly streetdriven so it will get an alternator and a PowerSteering-pump.
What options are out there to get all this to play nice together under the hood?
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: BigBlockMopar] #1331554
11/06/12 07:14 PM
11/06/12 07:14 PM
I would buy the pulleys and brackets for the alternator and power steering pump and then find the right lower blower pulley tto use, the snout on most roots superchargers for BB and Hemi Mopars will have plenty of room to clear the other parts inboard on the crankshaft
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: Cab_Burge] #1331555
11/07/12 06:32 AM
11/07/12 06:32 AM
The Netherlands
The Netherlands
I've got most of the pulley's already in possession (v-belt and blower), but I'm trying to figure out how to mount the crank's blowerbelt pulley.
I've been eyeballing it for a while and I would think the v-belt pulley should be in it's original position, as not to cause alignment/spacing issues with the alternator and P/S-pump.
My main worry is having to mount the crank's blower-pulley too far out with a spacer of some sort, which might cause more stress on the cranksnout and balancer. The blower's pulley would have to be spaced out the same amount.
Do most streetdriven blowermotors have a need for a balancer actually, or is just a simple hub to mount the pulley(s) on sufficient?
I understand having to make a new timing mark on the hub if the balancer itself is left out.
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: BigBlockMopar] #1331556
11/07/12 03:17 PM
11/07/12 03:17 PM
Contact March Pulleys to see if they have a kit for your application
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: BigBlockMopar] #1331557
11/07/12 04:17 PM
11/07/12 04:17 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I use the PS when I 1st got my blower and a 2v is used between the ballancer and blower pulley.You can shim out the PS pump with washers if needed and the PS pulley i had was for an a/c car.I have my 2 vee pullays still on and it has not stressed the blower or crank snout at all.
ps: are you using a belt drive waterpump or electric?
Stock alternator location or low mount?
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: Clanton] #1331558
11/07/12 04:51 PM
11/07/12 04:51 PM
The Netherlands
The Netherlands
I've got a CSR electric waterpump which I'll be using.
The engine-block is half-filled so it probably needs some good cooling during low rpm and idling.
Alternator will be mounted in the stock location if possible. Probably will be using a more modern smaller alternator.
I've ordered a 3.3" thick piece of aluminium 6.2" dia. roundstock today so I can make my own v-belt pulley on the lathe if needed.
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: BigBlockMopar] #1331559
11/09/12 11:30 AM
11/09/12 11:30 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
The p/s belt will be close to the w/p but will clear it using the outer vee pulley to drive it.I think the stock alt location is a problem when not using a w/p pulley as it is mounted higher than the p/s pump.I went to a low mount alt[GM SI10] after I got the electric w/p.
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: Clanton] #1331560
11/09/12 08:25 PM
11/09/12 08:25 PM
The Netherlands
The Netherlands
Thanks.
I will try to do a mockup this weekend to see where this will end up.
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: BigBlockMopar] #1331561
11/09/12 08:48 PM
11/09/12 08:48 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
You don't need a harmonic damper (balancer) on a Roots blown engine. People run them because they don't feel comfortable running an engine without one, but it isn't needed. That big belt does a great job soaking up harmonics. I ran a roots blown 528 Hemi on the street for 5 years, and shifted it at 7 grand running low 9's at the track, with no damper, just a hub. No high dollar crank, either. Just an Eagle 4.150 forged crank. I recommend adding a second keyway 180º from the stock keyway on the crank snout.
Personally, I would run 2 v-pulleys behind the crank pulley, and low mount the alternator.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: DusterDave] #1331562
11/09/12 11:24 PM
11/09/12 11:24 PM
N.Y.
V
VZCharger Offline
VZCharger  Offline
V
N.Y.
Just had my motor built by Barton and asked him about the need for a balancer. He said that while you could get away without it on a blower motor why would you? He said if you could run a balancer might as well do it. So mine has one.
70 Charger blown injected BB 07 Charger Daytona Plum Crazy #389 69 Coronet ragtop 96 Ram "Garlits Edition" 88 Conquest TSi
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: VZCharger] #1331563
11/10/12 10:57 AM
11/10/12 10:57 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Well, Mr. Barton just agreed with me. You CAN get away with it, meaning, no damage will occur. But then, he contradicts his own statement by saying, "why would you"????
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: DusterDave] #1331564
11/10/12 11:30 AM
11/10/12 11:30 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Although they say you do not need a harmonic balancer when using a blower belt,I ran that way for 6 years.After the second hub failure,went with the ATI superdamper and shortened the blower snout to bring the drive belts closer to the engine reducing the amount of spacers required to align all the pullies.I brought the water pump pulley so close that I had to change to a buttonhead bolt so the pulley would not rub on the water pump bolts.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: hemi-itis] #1331565
11/11/12 11:40 AM
11/11/12 11:40 AM
hemi-itis Offline
hemi-itis  Offline
The old setup
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: hemi-itis] #1331566
11/11/12 11:42 AM
11/11/12 11:42 AM
hemi-itis Offline
hemi-itis  Offline
Another
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: BigBlockMopar] #1331567
11/11/12 05:53 PM
11/11/12 05:53 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
If you can and get the chance show some pics please!I use a march under drive pulley and it rubbed the w/p and also used the button head allen bolts.I hope thing are going well.
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: Clanton] #1331568
11/11/12 08:47 PM
11/11/12 08:47 PM
The Netherlands
The Netherlands
I've found out today that in order to be able mount the belt at all, the pulleys need to be spaced out about 1.5" away from the damper and blower snout.
Any closer and the belt will rub the waterpump housing.
Noticed today that the boltholes in the balancer are thread with UNF and are only 5/16". I'm thinking of enlarging these to 3/8, just like the threads in the blower snout.
I've started making the custom V-pulley for my motor this weekend. The 'damper-side' is pretty much done. Now I need to create the V's and a register hub for the crank beltpulley.
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: BigBlockMopar] #1331569
11/11/12 09:06 PM
11/11/12 09:06 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I had a spacer made to fill the damper around the crank bolt to make a flush mount to the vee pulleys and support it all better.
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: Clanton] #1331570
11/11/12 10:41 PM
11/11/12 10:41 PM
hemi-itis Offline
hemi-itis  Offline
The register on the damper is 2.25,blower stuff is all 2 inch.You might have to open up the ID on the spacer enough to get flush on the damper.
Re: Rootsblower w/ alternator and P/S-pump. What options? [Re: hemi-itis] #1331571
11/12/12 05:32 AM
11/12/12 05:32 AM
The Netherlands
The Netherlands
I've got 2 sets of belt-pulleys to pick from; One set made by Mike Kuhl for a square-toothed belt and the other by BDS for a round-toothed belt.
But both pulleys already seem have a larger sized ID.
I still need to make the 'frontside' of the v-pulley/spacer, but when I'm exactly sure about it's required thickness I will finish it in the lathe.
I need to get myself a longer belt aswell as the ones I have are way too short. The large Indy-intake puts the blower a bit higher than other blower intakes I pressume.
VZCharger,
I just noticed you also have a Kuhl-blower on your mill aswell. Same for the INDY-intake.
Just for checking, what is your belt-length?
