Re: Rootsblower w/ alternator and P/S-pump. What options?
[Re: BigBlockMopar]
#1331557
11/07/12 04:17 PM
11/07/12 04:17 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I use the PS when I 1st got my blower and a 2v is used between the ballancer and blower pulley.You can shim out the PS pump with washers if needed and the PS pulley i had was for an a/c car.I have my 2 vee pullays still on and it has not stressed the blower or crank snout at all. ps: are you using a belt drive waterpump or electric? Stock alternator location or low mount?
[Re: Clanton]
#1331558
11/07/12 04:51 PM
11/07/12 04:51 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
I've got a CSR electric waterpump which I'll be using. The engine-block is half-filled so it probably needs some good cooling during low rpm and idling.
Alternator will be mounted in the stock location if possible. Probably will be using a more modern smaller alternator. I've ordered a 3.3" thick piece of aluminium 6.2" dia. roundstock today so I can make my own v-belt pulley on the lathe if needed.
[Re: BigBlockMopar]
#1331561
11/09/12 08:48 PM
11/09/12 08:48 PM
Posts: 1,845 Tampa
DusterDave
Tampa
You don't need a harmonic damper (balancer) on a Roots blown engine. People run them because they don't feel comfortable running an engine without one, but it isn't needed. That big belt does a great job soaking up harmonics. I ran a roots blown 528 Hemi on the street for 5 years, and shifted it at 7 grand running low 9's at the track, with no damper, just a hub. No high dollar crank, either. Just an Eagle 4.150 forged crank. I recommend adding a second keyway 180º from the stock keyway on the crank snout. Personally, I would run 2 v-pulleys behind the crank pulley, and low mount the alternator.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#1331562
11/09/12 11:24 PM
11/09/12 11:24 PM
Posts: 329 N.Y.
VZCharger
N.Y.
Just had my motor built by Barton and asked him about the need for a balancer. He said that while you could get away without it on a blower motor why would you? He said if you could run a balancer might as well do it. So mine has one.
70 Charger blown injected BB
07 Charger Daytona Plum Crazy #389
69 Coronet ragtop
96 Ram "Garlits Edition"
88 Conquest TSi
[Re: DusterDave]
#1331564
11/10/12 11:30 AM
11/10/12 11:30 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Although they say you do not need a harmonic balancer when using a blower belt,I ran that way for 6 years.After the second hub failure,went with the ATI superdamper and shortened the blower snout to bring the drive belts closer to the engine reducing the amount of spacers required to align all the pullies.I brought the water pump pulley so close that I had to change to a buttonhead bolt so the pulley would not rub on the water pump bolts.
[Re: Clanton]
#1331568
11/11/12 08:47 PM
11/11/12 08:47 PM
BigBlockMopar
The Netherlands
I've found out today that in order to be able mount the belt at all, the pulleys need to be spaced out about 1.5" away from the damper and blower snout. Any closer and the belt will rub the waterpump housing. Noticed today that the boltholes in the balancer are thread with UNF and are only 5/16". I'm thinking of enlarging these to 3/8, just like the threads in the blower snout. I've started making the custom V-pulley for my motor this weekend. The 'damper-side' is pretty much done. Now I need to create the V's and a register hub for the crank beltpulley.
[Re: Clanton]
#1331570
11/11/12 10:41 PM
11/11/12 10:41 PM
hemi-itis
The register on the damper is 2.25,blower stuff is all 2 inch.You might have to open up the ID on the spacer enough to get flush on the damper.
