Location R/H mirror on '69 B-bdy same as L/H or back ? #1331176
11/05/12 10:40 PM
11/05/12 10:40 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
On a '69 B-body with a R/H mirror is it mounted farther back than the L/H mirror. In this case the question is about a '69 A12 road runner without a remote adjust driver's side mirror (L/H) and a non-remote adjust passenger's side mirror (which wasn't available I was told).
http://a12mopar.com/yabb/YaBB.pl?num=1351407562
Re: Location R/H mirror on '69 B-bdy same as L/H or back ? [Re: A12] #1331177
11/06/12 09:38 AM
11/06/12 09:38 AM
SE Pa.
LimeliteAero Offline
SE Pa.
Im going to go with yes, it should be mounted farther toward the rear. I installed a mirror on my R/T which didnt start out in life with one and it seems to be out of position when I try to use/see in it.
Re: Location R/H mirror on '69 B-bdy same as L/H or back ? [Re: A12] #1331178
11/06/12 05:15 PM
11/06/12 05:15 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The mirror in the picture was never available on the RH door, it is a Left side only mirror. The correct mounting location for 68-70 is near where the one in the picture is placed, but that one looks a bit tooo far forward by about 1 inch. From the drivers seat you would be looking behind the wing frame, but the glass will not pivot far enough for the driver to see down the side of the car. So it is really only good for the passenger to see out of.
The 1966 and 1967 mirror was mounted forward so you looked through the wing window at the mirror, then the driver could see down the side of the car and actually use it it to see the right side rear when parking. The mirror was slightly blocked by the wing frame and that is likely why it was moved back on the door.
I have one 1967 and two 1970 b-bodies with the factory RH mirrors and this is how the factory did it.
Re: Location R/H mirror on '69 B-bdy same as L/H or back ? [Re: NANKET] #1331179
11/06/12 07:34 PM
11/06/12 07:34 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
That's not true my 69 Coronet came from the factory with manual mirrors.
Re: Location R/H mirror on '69 B-bdy same as L/H or back ? [Re: RJS] #1331180
11/06/12 07:39 PM
11/06/12 07:39 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
TAG
Post deleted by moparts [Re: A12] #1331181
11/06/12 10:47 PM
11/06/12 10:47 PM
Re: Location R/H mirror on '69 B-bdy same as L/H or back ? #1331182
11/06/12 10:51 PM
11/06/12 10:51 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
but try over in the General they like a good story and laugh
Re: Location R/H mirror on '69 B-bdy same as L/H or back ? [Re: A12] #1331183
11/07/12 12:11 AM
11/07/12 12:11 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
He's posted the same thing three times. He'll be gone shortly.
Re: Location R/H mirror on '69 B-bdy same as L/H or back ? [Re: RJS] #1331184
11/07/12 12:31 AM
11/07/12 12:31 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And my 71 Dart had both mirrors in the same location,driver remote,passenger manual..
Re: Location R/H mirror on '69 B-bdy same as L/H or back ? [Re: RJS] #1331185
11/07/12 02:31 AM
11/07/12 02:31 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
My 68 sport satellite that was was original when I purchased it has the same mirror.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
