Re: Location R/H mirror on '69 B-bdy same as L/H or back ?
[Re: NANKET]
#1331179
11/06/12 07:34 PM
11/06/12 07:34 PM
Posts: 6,224 JERSEY
RJS
JERSEY
The mirror in the picture was never available on the RH door, it is a Left side only mirror. The correct mounting location for 68-70 is near where the one in the picture is placed, but that one looks a bit tooo far forward by about 1 inch. From the drivers seat you would be looking behind the wing frame, but the glass will not pivot far enough for the driver to see down the side of the car. So it is really only good for the passenger to see out of.
The 1966 and 1967 mirror was mounted forward so you looked through the wing window at the mirror, then the driver could see down the side of the car and actually use it it to see the right side rear when parking. The mirror was slightly blocked by the wing frame and that is likely why it was moved back on the door.
I have one 1967 and two 1970 b-bodies with the factory RH mirrors and this is how the factory did it.
That's not true my 69 Coronet came from the factory with manual mirrors.
[Re: RJS]
#1331180
11/06/12 07:39 PM
11/06/12 07:39 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Post deleted by moparts
[Re: A12]
#1331181
11/06/12 10:47 PM
11/06/12 10:47 PM
#1331182
11/06/12 10:51 PM
11/06/12 10:51 PM
Posts: 21,499 N.E. OHIO, USA
A12
N.E. OHIO, USA
[Re: RJS]
#1331184
11/07/12 12:31 AM
11/07/12 12:31 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
And my 71 Dart had both mirrors in the same location,driver remote,passenger manual..
[Re: RJS]
#1331185
11/07/12 02:31 AM
11/07/12 02:31 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
My 68 sport satellite that was was original when I purchased it has the same mirror.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
