B1BS heads #1327278
10/28/12 10:16 AM
10/28/12 10:16 AM
Mo.
supercomp Offline OP
Mo.
Can you max wedge port B1BS heads? How much differance would it make to ones that have already been cnc standard ported and maybe adding 2.25 valves? Now has 2.200 valves.
Re: B1BS heads [Re: supercomp] #1327279
10/28/12 10:25 AM
10/28/12 10:25 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I tried to, broke through at the push rod pinch. you could let it neck down around that part. I ended up just going to max wedge height. This was on ET Performance's cnc standard port window heads.
Re: B1BS heads [Re: supercomp] #1327280
10/28/12 01:06 PM
10/28/12 01:06 PM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
I had a set of B1BS with as much work as one could do to them. The cost of making them any better is not worth it in my opinion. I would just buy set of cnc 440-1s with 2.25 valves and Jessel Rockers..Or step up to Original B-1s with T&Ds
Re: B1BS heads [Re: Mpetros] #1327281
11/02/12 12:16 AM
11/02/12 12:16 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
My B1BS heads have Max Wedge port and make real good power with a 2.20" valve. It is a 498CID and made right at 900HP on Alky.
I haven't hear of to many 440-1 heads doing that.
I do have a set of T&D paired shaft rockers on it.
Indy tunnel ram
I like the B1BS heads
Re: B1BS heads [Re: supercomp] #1327282
11/02/12 02:37 AM
11/02/12 02:37 AM
Jeff at MCH CNC ported a set of B1-BS I had to M.W. size They flowed 350 CFM at 700 on a Super Flow 600 bench at 28 inches, I put them on a 3.91 stroke 471 C.I. 440 bracket motor for a good customer in SO CA several years ago. The motor made 720 HP at 7000 RPM (it was still climbing but the customer wanted to stop the tests at 7000 RPM )on a cheap sheet metal fabricated tunnel ram and two Holley 750 D.P., KB forged piston with around 12.8 to 1 comp. ratio. Nothing exotic
Re: B1BS heads [Re: Cab_Burge] #1327283
11/02/12 11:07 AM
11/02/12 11:07 AM
Mo.
Mo.
Thanks for the info. Ours flow 355 at .700. They're on a 511 S/G Roadster. Would like to pick up a few mph.
Re: B1BS heads [Re: supercomp] #1327284
11/02/12 01:51 PM
11/02/12 01:51 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Your getting 355 with a standard port window?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: B1BS heads [Re: Von] #1327285
11/02/12 02:12 PM
11/02/12 02:12 PM
ohio
dbran451 Offline
dbran451  Offline
ohio
Nick at compu-flow did mine they flow 331@.700
Re: B1BS heads [Re: supercomp] #1327286
11/02/12 02:27 PM
11/02/12 02:27 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
I think Dwayne said they were near Max Wedge:
.500-296.4/228.9
.600-326.0/244.4
.650-331.4/249.8
.700-306.3/254.5
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: B1BS heads [Re: BBLM23] #1327287
11/03/12 10:48 AM
11/03/12 10:48 AM
Mo.
Mo.
Here
Re: B1BS heads [Re: BBLM23] #1327288
11/04/12 01:41 AM
11/04/12 01:41 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
.500-296.4/228.9
.600-326.0/244.4
.650-331.4/249.8
.700-306.3/254.5
Almost identical to the numbers on the BS heads Dwayne did for me.
Re: B1BS heads [Re: supercomp] #1327289
11/04/12 03:24 AM
11/04/12 03:24 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I talked to someone at www.etheads.com because they say they can cnc the B1-b/s to 355 cfm @ 0.700".
They told me that was with max wedge port size.
I already have the Manely severe duty 2.25" intakes and exhaust valves (the larger intake didn't help flow on the Stage1 (basic port cleanup) Koffels ported heads I have.
Re: B1BS heads [Re: 451Mopar] #1327290
11/04/12 05:15 PM
11/04/12 05:15 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
If I remember correct, my heads had epoxy in cylinder 1,2 and 7,8, the corner cylinders. It was the push rod pinch.
My 540 made 811hp, but Kasper made 842hp with less cubes( under 500) mostly for a custom grind cam from Scott B.
I still have valves and seats, necessary for 2.25 valves change, if anyone wants a good deal. Brand new parts, heads still have 2.20 valves.
Re: B1BS heads [Re: RT540] #1327291
11/04/12 06:23 PM
11/04/12 06:23 PM
Mo.
Mo.
Hi Tom, how's things going in Sweden? Who know's maybe Scott's flow bench was on crack when he flowed ours.lol. sounds like they're not worth putting more money in. Time for bigger heads. Thanks guy's for your help.
Re: B1BS heads [Re: supercomp] #1327292
11/06/12 03:05 PM
11/06/12 03:05 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Hi Allen !
All is good here, been busy with a big project at work last year, but I will try to spend more time in the garage now
