Re: B1BS heads
[Re: Mpetros]
#1327281
11/02/12 12:16 AM
11/02/12 12:16 AM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
My B1BS heads have Max Wedge port and make real good power with a 2.20" valve. It is a 498CID and made right at 900HP on Alky. I haven't hear of to many 440-1 heads doing that. I do have a set of T&D paired shaft rockers on it. Indy tunnel ram I like the B1BS heads
Re: B1BS heads
[Re: supercomp]
#1327282
11/02/12 02:37 AM
11/02/12 02:37 AM
Posts: 43,214 Bend,OR USA
Cab_Burge
Jeff at MCH CNC ported a set of B1-BS I had to M.W. size They flowed 350 CFM at 700 on a Super Flow 600 bench at 28 inches, I put them on a 3.91 stroke 471 C.I. 440 bracket motor for a good customer in SO CA several years ago. The motor made 720 HP at 7000 RPM (it was still climbing but the customer wanted to stop the tests at 7000 RPM )on a cheap sheet metal fabricated tunnel ram and two Holley 750 D.P., KB forged piston with around 12.8 to 1 comp. ratio. Nothing exotic
Re: B1BS heads
[Re: supercomp]
#1327284
11/02/12 01:51 PM
11/02/12 01:51 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Ours flow 355 at .700.
Your getting 355 with a standard port window?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: B1BS heads
[Re: supercomp]
#1327286
11/02/12 02:27 PM
11/02/12 02:27 PM
Posts: 2,273 Greenville, South Carolina
BBLM23
I think Dwayne said they were near Max Wedge: .500-296.4/228.9 .600-326.0/244.4 .650-331.4/249.8 .700-306.3/254.5
Walter 1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph Racing Pro in street trim. 1981 Aries ARC 548 B1 8.88 at 147mph (footbraking) 1996 Ram 2500 V10 16.52 at 80mph 1981 Reliant 400
Re: B1BS heads
[Re: BBLM23]
#1327287
11/03/12 10:48 AM
11/03/12 10:48 AM
Posts: 3,441 Mo.
supercomp
Mo.
Re: B1BS heads
[Re: BBLM23]
#1327288
11/04/12 01:41 AM
11/04/12 01:41 AM
Von
NE Oklahoma
Almost identical to the numbers on the BS heads Dwayne did for me.
Re: B1BS heads
[Re: supercomp]
#1327289
11/04/12 03:24 AM
11/04/12 03:24 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I talked to someone at www.etheads.com because they say they can cnc the B1-b/s to 355 cfm @ 0.700". They told me that was with max wedge port size. I already have the Manely severe duty 2.25" intakes and exhaust valves (the larger intake didn't help flow on the Stage1 (basic port cleanup) Koffels ported heads I have.
Re: B1BS heads
[Re: 451Mopar]
#1327290
11/04/12 05:15 PM
11/04/12 05:15 PM
Posts: 1,664 North Sweden
RT540
North Sweden
If I remember correct, my heads had epoxy in cylinder 1,2 and 7,8, the corner cylinders. It was the push rod pinch. My 540 made 811hp, but Kasper made 842hp with less cubes( under 500) mostly for a custom grind cam from Scott B.
I still have valves and seats, necessary for 2.25 valves change, if anyone wants a good deal. Brand new parts, heads still have 2.20 valves.
