2000 Sebring - New battery, not cranking #1319523
10/12/12 06:33 PM
10/12/12 06:33 PM
New Jersey, USA
JeffRacerG Offline OP
New Jersey, USA
My old reliable 2000 Sebring would not crank over when the key is turned, so since I've never put a battery in it before I put in a new one. Still, the engine will not crank over when the key is turned. From your experience, what else could be wrong, where is the part and how do I fix it? Thanks in advance!
Re: 2000 Sebring - New battery, not cranking [Re: JeffRacerG] #1319524
10/12/12 06:36 PM
10/12/12 06:36 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Try holding the key in start and move the shifter if it's an auto. Could just be a linkage adjustment or neurtal saftey switch issue.
Re: 2000 Sebring - New battery, not cranking [Re: stumpy] #1319525
10/12/12 10:12 PM
10/12/12 10:12 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Turn on your headlights...and try to start the car...if the lights stay on its the starter...if u do this in the daytime you would need a helper...at night u can do it yourself
Re: 2000 Sebring - New battery, not cranking [Re: AARCONV] #1319526
10/12/12 11:26 PM
10/12/12 11:26 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Had a similar situation with our Sebring a couple months ago. Battery showed a little low on the meter. Cleaned connections, no start. Jumper cables, no start. Had to put a starter in it.
Re: 2000 Sebring - New battery, not cranking [Re: pinkduster] #1319527
10/13/12 11:29 AM
10/13/12 11:29 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Had this happen with my '99 LXi last week.
All the above suggestions are great and if they don't locate the issue here's what I found.
The band clamps for the + and - have an inner band I had to remove and clean because there was corrosion between them and the main clamp.
Really hard to detect if you aren't specifically looking for it.
Good luck!
Re: 2000 Sebring - New battery, not cranking [Re: JeffRacerG] #1319528
10/13/12 04:24 PM
10/13/12 04:24 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
check the under hood fuse box and make sure that the starter fuse is good. No kidding had a coustomers car towed in for that issue.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: 2000 Sebring - New battery, not cranking [Re: yella71] #1319529
10/13/12 05:36 PM
10/13/12 05:36 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Ditto on the starter fuse. If is blown and keeps blowing it, its new starter time.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
