Re: 2000 Sebring - New battery, not cranking
[Re: pinkduster]
#1319527
10/13/12 11:29 AM
10/13/12 11:29 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Had this happen with my '99 LXi last week. All the above suggestions are great and if they don't locate the issue here's what I found. The band clamps for the + and - have an inner band I had to remove and clean because there was corrosion between them and the main clamp. Really hard to detect if you aren't specifically looking for it. Good luck!
[Re: JeffRacerG]
#1319528
10/13/12 04:24 PM
10/13/12 04:24 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
check the under hood fuse box and make sure that the starter fuse is good. No kidding had a coustomers car towed in for that issue.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
