Aeromotive fuel pump stalls?? #1316305
10/06/12 05:02 PM
10/06/12 05:02 PM
London,Ontario,Canada
1962Savoy Offline OP
I have a Aeromotive 2000 pump and a matching speed control box so I can drive my car on the street. For some reason unknown to me the pump shuts down intermittently, could be a block may maybe two but I don't get very far? It was working fine and now this! Any Ideas what may cause this? the tech at aeromotive is stumped as well.
Re: Aeromotive fuel pump stalls?? [Re: 1962Savoy] #1316306
10/06/12 06:38 PM
10/06/12 06:38 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Bad tach signal?
Re: Aeromotive fuel pump stalls?? [Re: Twin Turbo Mower] #1316307
10/06/12 07:11 PM
10/06/12 07:11 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Could the pump be getting hot from no air movement around it?
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Aeromotive fuel pump stalls?? [Re: 1962Savoy] #1316308
10/06/12 07:58 PM
10/06/12 07:58 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Well you could put a smaller line feeding the filter with some more 90* bends! I can tell you right there it will give you trouble on the street when the fuel heats up...As far as the controller, never ran one or saw the need for one...Vapor lock will occur if you restrict inlet fuel. And why do I not see a return line off the pump?
Re: Aeromotive fuel pump stalls?? [Re: 1962Savoy] #1316309
10/06/12 08:50 PM
10/06/12 08:50 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I agree with Dragula.
That's a tiny feed line, it needs to be bigger.
What micron is the filter?
Re: Aeromotive fuel pump stalls?? [Re: Twin Turbo Mower] #1316310
10/06/12 09:52 PM
10/06/12 09:52 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
hard to tell in pic but is pump even below the cell.
Mopar Performance
Re: Aeromotive fuel pump stalls?? [Re: 1962Savoy] #1316311
10/06/12 10:05 PM
10/06/12 10:05 PM
Mt.Vernon IL
Mt.Vernon IL
The pump controller works off what rpm the engine is running at or tach signal. I have the same controller on my car. I figure you have a bad signal going to the controller. If the controller does not see a signal it does not tell the pump to run. Or you have the max output for the pump set at to high rpm.
http://aeromotiveinc.com/wp-content/uploads/2009/12/16306.pdf
Also you may be losing key on power to it while it is running thus shutting the pump down.
Re: Aeromotive fuel pump stalls?? [Re: Twin Turbo Mower] #1316312
10/06/12 10:28 PM
10/06/12 10:28 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Check your tank vent... looks kinda small + its looped, could have some fuel @ the low spot in the bend blocking air flow
Re: Aeromotive fuel pump stalls?? [Re: Twin Turbo Mower] #1316313
10/07/12 08:19 AM
10/07/12 08:19 AM
Cincinnati, Ohio
Cincinnati, Ohio
Controller or not, that inlet line will never work under hi demand and hi heat, no way. It will slowly kill the pump, I bet some of you have been there...
Plus I need to know more about the filter in front of the pump.
Re: Aeromotive fuel pump stalls?? [Re: Challenger 1] #1316314
10/07/12 08:42 AM
10/07/12 08:42 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
The filter before the pump is prolly 100micron and the one after is 10micron! Thats is what aeromotive recomends anyways and how my new system is setup. man that pump looks kinds above where it pulls from cell...also the fitting coming right outta the fuel cell before the filter looks like a 6 then an 8 after. could be wrong though.
Mopar Performance
Re: Aeromotive fuel pump stalls?? [Re: Challenger 1] #1316315
10/07/12 10:08 AM
10/07/12 10:08 AM
Mt.Vernon IL
Mt.Vernon IL
The controller is ment to promote pump life by not heating up the fuel from constant full load. Only goes to full load at the rpm like 4500 or up you set it to. Much like the timing advance curve in a mechanical distributor. From what he is saying is the pump shuts off completely, or at least thats what I understand he is saying.
Re: Aeromotive fuel pump stalls?? [Re: Twin Turbo Mower] #1316316
10/07/12 01:08 PM
10/07/12 01:08 PM
California
Mad Dart Offline
Mad Dart  Offline
California
Too much $$ at risk to be running Aeromotive products for my taste. Guys have had great success running the Walbro GSL-392's. They are $100 each and I run them in Multiples. No pump controller needed, They are quieter, less expensive, reliable, will lift fuel, act as a dead head pump if turning them on at different times and flow some serious fuel. I am running dual 10an feeds from the Cell to the manifold and 10an feed to the regulator. 8an return. This set up here in triplets is good for over 1600 Boosted EFI HP.
Re: Aeromotive fuel pump stalls?? [Re: Mad Dart] #1316317
10/07/12 08:18 PM
10/07/12 08:18 PM
MI
68shifter Offline
68shifter  Offline
MI
http://aeromotiveinc.com/wp-content/uploads/2009/12/11202.pdf
I don't see where you plumbed the return line off the pump itself, just on the other side of the motor.
Fuel line is too small as well. They recommend -10, I use -12 inlet and -10 all the way to the regulator. Works great thus far. Good luck.
