Re: Aeromotive fuel pump stalls??
[Re: Twin Turbo Mower]
#1316307
10/06/12 07:11 PM
10/06/12 07:11 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Could the pump be getting hot from no air movement around it?
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: 1962Savoy]
#1316308
10/06/12 07:58 PM
10/06/12 07:58 PM
Posts: 12,397 Taxes & Virus's R-US, NY
Dragula
Well you could put a smaller line feeding the filter with some more 90* bends! I can tell you right there it will give you trouble on the street when the fuel heats up...As far as the controller, never ran one or saw the need for one...Vapor lock will occur if you restrict inlet fuel. And why do I not see a return line off the pump?
#1316310
10/06/12 09:52 PM
10/06/12 09:52 PM
Posts: 6,295 U.S.
moparniac
U.S.
hard to tell in pic but is pump even below the cell.
Mopar Performance
[Re: 1962Savoy]
#1316311
10/06/12 10:05 PM
10/06/12 10:05 PM
Posts: 1,056 Mt.Vernon IL
Twin Turbo Mower
Mt.Vernon IL
The pump controller works off what rpm the engine is running at or tach signal. I have the same controller on my car. I figure you have a bad signal going to the controller. If the controller does not see a signal it does not tell the pump to run. Or you have the max output for the pump set at to high rpm. http://aeromotiveinc.com/wp-content/uploads/2009/12/16306.pdfAlso you may be losing key on power to it while it is running thus shutting the pump down.
#1316313
10/07/12 08:19 AM
10/07/12 08:19 AM
Challenger 1
Cincinnati, Ohio
Controller or not, that inlet line will never work under hi demand and hi heat, no way. It will slowly kill the pump, I bet some of you have been there...
Plus I need to know more about the filter in front of the pump.
[Re: Challenger 1]
#1316314
10/07/12 08:42 AM
10/07/12 08:42 AM
Posts: 6,295 U.S.
moparniac
U.S.
The filter before the pump is prolly 100micron and the one after is 10micron! Thats is what aeromotive recomends anyways and how my new system is setup. man that pump looks kinds above where it pulls from cell...also the fitting coming right outta the fuel cell before the filter looks like a 6 then an 8 after. could be wrong though.
Mopar Performance
[Re: Challenger 1]
#1316315
10/07/12 10:08 AM
10/07/12 10:08 AM
Twin Turbo Mower
Mt.Vernon IL
The controller is ment to promote pump life by not heating up the fuel from constant full load. Only goes to full load at the rpm like 4500 or up you set it to. Much like the timing advance curve in a mechanical distributor. From what he is saying is the pump shuts off completely, or at least thats what I understand he is saying.
[Re: Mad Dart]
#1316317
10/07/12 08:18 PM
10/07/12 08:18 PM
Posts: 1,169 MI
68shifter
MI
http://aeromotiveinc.com/wp-content/uploads/2009/12/11202.pdfI don't see where you plumbed the return line off the pump itself, just on the other side of the motor. Fuel line is too small as well. They recommend -10, I use -12 inlet and -10 all the way to the regulator. Works great thus far. Good luck.
