Page 3 of 3 1 2 3
Re: Edelbrock Carb Heat Soak Issue. [Re: TimS] #1311873
10/07/12 09:56 AM
10/07/12 09:56 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""We are not talking those POS cool carb spacers.""
""But If you having trouble with this, then I change the manifold to something without a heat riser or block yours before going any farther.""
That is good advice for both the Edy-9266,the Cool Carb members, and anyone trying to drive on todays crapty gas blend.
Re: Edelbrock Carb Heat Soak Issue. [Re: YO7_A66] #1311874
10/07/12 11:57 AM
10/07/12 11:57 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I have a 1407 on my stock 70 440.
It has the same problem of warm start issue.
When I pulled the engine for a re seal and cosmetic resto I blocked the heat crossover but it still has a warm start problem if I touch the gas pedal when starting.
If I just start it with the key and NO pedal it will start 9 out of 10 times.
I also have a factory thick gasket but may order up that one that was posted to see what happens.
I just ordered step up springs last night due to a bog when nailing the car.
Ron
Re: Edelbrock Carb Heat Soak Issue. [Re: RJS] #1311875
10/08/12 07:35 AM
10/08/12 07:35 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Ron
I like driving mine in the Winter before the snow flies and carb icing on the bottom becomes an issue then at cold startup, but overall, the lesser of the two issues if I block the crossovers. Probably the best thing to do. I bought the Fel pro valley pan with the blocked crossovers and put it on my Roadrunner quite a few years ago. Those things open up eventually. It did on that.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Edelbrock Carb Heat Soak Issue. [Re: TimS] #1311876
10/08/12 06:37 PM
10/08/12 06:37 PM
South Carolina
W
warpspeed Offline
warpspeed  Offline
W
South Carolina
Wow! I cant believe I am doing this again. When there is a "vapor lock" does that mean that the carb won't allow any more fuel into the carb? If that is the case, just how do you fix it? I have a 318 engine, with an edelbrock carb, a dual plane intake, a circulating fuel system from the filter just down stream from the mechanical pump, a clear filter at the carb, (just to make sure I can tell whether the fuel is moving), and the fuel lines are away from any heat sink. The carb isn't that hot, that is too hot to touch. There is the 1/2" gasket you mention to insulate it from the manifold, (yes it really is hot). But, we ran with the car for over a year without any problems before even insulating the carb from the manifold.
Noticed the coil, a new one, is really hot. Is that normal?
Noticed that the fuel was slowly getting less and less in the clear filter bowl. Especially as I would test the acceleration pump. This pump was squirting lightly but not putting out much fuel. Yeah, I get it may be lean. I will fix that. When it quit, it was 1/4 mile from the house. I left it in a parking lot while I worked on it. Changed out the fuel pump, didn't help. Then eight hours later, I went back by and it started up so I could drive it the rest of the way home. But it was completely cooled off.
This is getting really frustrating! I know the carb is the culprit and I am getting really mad at it, but, I just feel that it will run fine if I can just get this problem eliminated. Just need to see if the vapor lock is the problem and how to stop it. It just didn't seem to be a really heat problem.
Re: Edelbrock Carb Heat Soak Issue. [Re: warpspeed] #1311877
10/08/12 09:15 PM
10/08/12 09:15 PM
Do you have an operational heat riser/crossover? rearward from the mechanical pump there's no pinholes and the sock ain't restricted? I have a DD 318 with an eddie 1406 & no issues even with E10 but my eng compartment is open & the heat riser is non op.
Re: Edelbrock Carb Heat Soak Issue. [Re: RapidRobert] #1311878
10/09/12 10:29 AM
10/09/12 10:29 AM
South Carolina
W
warpspeed Offline
warpspeed  Offline
W
South Carolina
I haven't checked the heat riser. There isn't a cat anymore since we don't have to have the car inspection here. Even in NC, a car this old isn't run through emissions. But, I will look at this out.
Re: Edelbrock Carb Heat Soak Issue. [Re: warpspeed] #1311879
10/09/12 11:14 AM
10/09/12 11:14 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Since most complain about the Eddy and it's problems which I never had,why not get a good used AVS or AFB that suits your needs,rework it and be done ? There are enough for just about any application.
Carb._________Venturi dia._________Bore dia.
CFM__________Pri.____Sec._______Pri._____Sec.
750 ................1 7/16.....1 9/16 ......1 11/16....1 11/16
625.................1 3/16.....1 9/16.......1 7/16......1 11/16
575.................1 1/4.......1 9/16.......1 9/16......1 11/16
500.................1 3/16.....1 1/4.........1 7/16 .....1 11/16
400 ................1 1/8.......1 1/4.........1 7/16......1 7/16
Re: Edelbrock Carb Heat Soak Issue. [Re: 62maxwgn] #1311880
10/09/12 11:24 AM
10/09/12 11:24 AM
South Carolina
W
warpspeed Offline
warpspeed  Offline
W
South Carolina
Sounds like a good idea. I really want to get this carb going. So, I am going to stick to it the best I can. My wife thinks I should just get rid of the whole care because of this one little problem. What I can't understand is why there wasn't a problem with it for more than a year of driving. Quality of gas a problem? I will jump up to a mid grade if necessary, but, I really think there is a good solution to this problem without going to that extreme. And my heat riser appears to be working okay. So, it is back to tearing the carb down, going to a higher flow rate, and having a back up carb ready to go on at a moments notice.
Re: Edelbrock Carb Heat Soak Issue. [Re: YO7_A66] #1311881
10/09/12 02:11 PM
10/09/12 02:11 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
My
If you use a manifold without a heat riser or have them blocked, then you really don't need a carb spacer to keep the carb cool. So that's why I think so poorly of the cool carb things, because they only can be used on a cool engine. What good is that??
As you know I have a very good running 340 with a victor340 manifold with no heat risers with my 1405 eddie carb sitting right on the manifold with only a gasket.
And my car runs great even in 110 degree temps in Vegas and in 100 degree heat that we had here this summer. It has idled for over a 1/2 hour on a 100 degree day just recently with no issues and it starts with a flick of the key.
Like I said in the past, I thinks it's the dumbest thing in the world to use aluminum to isolate heat. I want to be on record saying this.
Get your tuneup in order and enjoy your cars without overheating like I do almost everyday.
Re: Edelbrock Carb Heat Soak Issue. [Re: lilcuda] #1311882
10/09/12 02:49 PM
10/09/12 02:49 PM
Cincinnati, Ohio
Cincinnati, Ohio
I cured all of my Edelbrock 1406 issues by unbolting it and installing a Holley 650 DP. Problems solved. Sold the Edelbrock to a friend and never looked back.
I'm sure you learned nothing!! way to go!!
Re: Edelbrock Carb Heat Soak Issue. [Re: Challenger 1] #1311883
10/10/12 07:47 AM
10/10/12 07:47 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
The Holley bowls hung on each end help with the heat issue while the Carters and Edelbrocks are centered in the body across the heat path. Fact is, these cars mainly had Carters on them from the factory with a much different gas blend than we have today. My immediate plan is to check on Phenolic materials to see what kind of heat they will withstand and make a spacer. These fiber spacers on the market have to be used with the heat crossover blocked, and I agree, if your going to block the crossover you don't even need the spacer.
Re: Edelbrock Carb Heat Soak Issue. [Re: TimS] #1311884
10/10/12 09:40 AM
10/10/12 09:40 AM
South Carolina
W
warpspeed Offline
warpspeed  Offline
W
South Carolina
I bought a phenolic (1/2") spacer for a few bucks off ebay. It was here really fast. Look it up, it wasn't expensive.
Speaking of which, I started to take the carb off the engine last night to replace the Edelbrock spacer with this thicker spacer and found the nuts on the carb loose. The back left one was so loose, it was moving up and down from the vibration from the motor. I replaced the spacers and started it up. Didn't hear or feel any difference, but, I assure you I can't help but think this is the reason for the last issues. Last Saturday, the car ran fine for hour or so, stopping and starting here and there until I was coming back to the warehouse. Don't understand why it would restart and run well enough to drive it back to the warehouse, 1/4 mile away, but, THIS has to be the reason why I was having the last problem. Anyway, the spacer is there, fuel lines have been routed around all hot spots, the carb is tuned and I am going for a run to see if this stops the shut downs.
Re: Edelbrock Carb Heat Soak Issue. [Re: warpspeed] #1311885
10/10/12 10:39 AM
10/10/12 10:39 AM
I would have tightened the nuts as is to see if that was it but yes holler if it's all good now
Re: Edelbrock Carb Heat Soak Issue. [Re: RapidRobert] #1311886
10/10/12 11:14 AM
10/10/12 11:14 AM
South Carolina
W
warpspeed Offline
warpspeed  Offline
W
South Carolina
yeah, you are right, but I wanted to replace the edelbrock spacer anyway. We'll see if it works.
Re: Edelbrock Carb Heat Soak Issue. [Re: RapidRobert] #1311887
10/15/12 10:36 AM
10/15/12 10:36 AM
South Carolina
W
warpspeed Offline
warpspeed  Offline
W
South Carolina
Drove the car home (15 miles) on Saturday without incident. Believe the first problem was the coil wire barely connected, then the nuts holding the carburator down. Even though I didn't stop and start a bunch of times, I can't help but believe that the loose nuts were the last straw. With the new 1/2" spacer, I think the heat sink problem is gone. I took off one circulating filter and have left a final filter at the carburator. It is indicating that the fuel pressure is better and flow is good. There are a lot of little things that hurt, but it appears they are all good now. Will drive the car now without fear it wants to shut down.
Thanks for all the imput and great imformation.
Page 3 of 3 1 2 3
