Re: broadcast sheet ?
[Re: 69CoronetRT]
#1310058
09/25/12 01:15 AM
09/25/12 01:15 AM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Good to know Doug. I have all mine filed by VIN & plant, so I'll take a closer look when I can to see if I can narrow it down any further. Thanks! (Hamms)
[Re: 1cuda]
#1310059
09/25/12 03:05 AM
09/25/12 03:05 AM
Posts: 21,519 N.E. OHIO, USA
A12
N.E. OHIO, USA
quick question-what are the four digit numbers at the end of a 69 e series lynch road broadcast sheet on line 5 for? all the best frank.
I wrote this over on the A12 Registry:
Isn't row 5 the "LABELS" row? The other end (left side) of that row has the "IDLE" (for emissions compliance adjustment) and "TIRE" (driver's door with air pressure, GVWR). Would that be two of the other labels on the car? That leaves the: jack instructions, the driver's door jam with the NHTSA "MEETS FEDERAL MOTOR VEHICLE SAFETY STANDARDS", the air filter cover labels, the radiator coolant label, the jack base label, the 4-speed reverse light warning (if that could be considered a government required warning or safety feature which it WAS). What else am I for sure missing? How about the window (Monroney Label) sticker? I guess we need to look at some more Broadcast sheets to see how many variations or different numbers there are for A12's. Any labels on Bee's that are not on Runner's? Looking at an A12 rr now that has a 2 under 13 and 269 under 14. An A12 Bee with a 2 under 13 and 132 under 14 Okay a quick look at some other model year broadcast sheets shows boxes for "EXHAUST" and the performance cars all seem to have a "02" under for what I would suspect DUAL EXHAUST PIPES????? So maybe 13 is for exhausts on the '69 Broadcast Sheet (BS)? Then there is a box labeled 'CAR HEIGHT" with a 3-digit code, maybe that's what the 269 or 132 is for??? Any other numbers besides 02, under 13 or 132, 269 and 276 under 14? RoadrunnerJD, John wrote on the A12 Registry:
Mine has the numbers 030 under the 14 and all I can read under the 13 is a last digit of 0?
which could be another "132"?
[Re: A12]
#1310060
09/25/12 03:26 AM
09/25/12 03:26 AM
A12
N.E. OHIO, USA
Nothing is making any sense, found some Broadcast Sheets with either a 1 or a 2 under 13 and nothing else (so far), majority were "2"
Under 14 (ALL A12 cars) I found; 132, 269, 276, 313, 212 (or 218 can read the third digit) 461 62?, 344, 241, and some with NOTHING under 14 and some with nothing under 13 on the same sheet.
[Re: A12]
#1310061
09/25/12 03:40 AM
09/25/12 03:40 AM
Posts: 17,517 Las Vegas, NV
6bblgt
Las Vegas, NV
Anyone know what hours 1st & 2nd shift ran "back-in-the-day"? I went thru a few b'cast sheets. (if it's a 4 digit time stamp) Plant box 13/box 14 SPDA 1/697 329 0/794 426 2/026 426 1/690 501 0/629 605 * 06:29 = 6:17 AM earliest B none 211 2/350 214 * 23:50 = 11:30 PM latest (hard to read "M" code GTS) & 214 was a Friday 1/350 312 1/379 411 0/922 427 1/508 506 2/182 523 * 21:82 = 9:50 PM 1/10? 606 0/950 609 0/802 610 1/301 612 F 1/857 505
