Engine Builders. Torque Plate Question. #1309791
09/24/12 11:30 AM
09/24/12 11:30 AM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
I understand that you should use the same type of fastener for the plate as you are using for the heads. Bolts or studs. It is also my understanding that you should use the same length, using spacers if needed. Here is the problem. Early hemis head bolts and/or studs also hold the rocker stands. This means bolts or studs in 7.5-8.5 inch length. Should I make up spacers for that length of bolt/stud, or is it just not needed and/or practical in this case? Thanks.
Re: Engine Builders. Torque Plate Question. [Re: TrWaters] #1309792
09/24/12 11:32 AM
09/24/12 11:32 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Can you put the shaft cradle on top of the plate?
I would think the rockers would be in the way, but you can remove them
Re: Engine Builders. Torque Plate Question. [Re: DJVCuda] #1309793
09/24/12 11:39 AM
09/24/12 11:39 AM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
No,with the way the rocker stands are made, there is only approximately 3.75 diameter clearance between them. Engine is a 4 inch bore. Also, the heads are 2+ inches thicker than the plate.
Re: Engine Builders. Torque Plate Question. [Re: TrWaters] #1309794
09/24/12 11:45 AM
09/24/12 11:45 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Spacers, although I don't know how much difference it will make.
Boffin Emeritus
Re: Engine Builders. Torque Plate Question. [Re: TrWaters] #1309795
09/24/12 11:55 AM
09/24/12 11:55 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
on the small blocks I have done there are spacers, and i believe to have the required effect on the studs / bolts you need to stretch them accordingly. So if you need to cut some tube up the thickness of the rockers, then thats what ya have to do.
Re: Engine Builders. Torque Plate Question. [Re: TrWaters] #1309796
09/24/12 01:16 PM
09/24/12 01:16 PM
Put a head on it with the rocker assembly torque down , use a dial bore gauge through the bottom of the cylinders to check the roundness. then do the same thing with the torque plate using spacers I use to hone 340 from the bottom with both heads torque down on them , I always torque the mains and oil filter adapter along with the motor mounts also, some guys install and torque the SB water pump timing covers also
Re: Engine Builders. Torque Plate Question. [Re: Cab_Burge] #1309797
09/24/12 02:26 PM
09/24/12 02:26 PM
Delray beach, Florida
P
Performance Only Offline
P
that's something i'd like to see. how did you get the cylinders straight and round if the hone can't come partially through the top of the cylinder? (or maybe you were just using a ball hone to rough them up?)
Tom, you only need to have the same amount of thread engagement in the block as what it will have with the heads and rockers bolted on. there's no need to have the same overall lengh fastener in your application.
machine shop owner and engine builder
Re: Engine Builders. Torque Plate Question. [Re: Performance Only] #1309798
09/24/12 03:28 PM
09/24/12 03:28 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
My old Ford Machinist torqued the Scattershield in place along with the Torque plates, said the back bores o the windsor distort from the back of the block as well.
WIZE
In Car:
Re: Engine Builders. Torque Plate Question. [Re: Streetwize] #1309799
09/24/12 06:00 PM
09/24/12 06:00 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
Thanks Dan. I was reading over on Speed Talk, and that seemed to be the detail that kept came up.
Re: Engine Builders. Torque Plate Question. [Re: Performance Only] #1309800
09/24/12 06:15 PM
09/24/12 06:15 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Ill bet those heads took a beating too,
Re: Engine Builders. Torque Plate Question. [Re: Moparnut426] #1309801
09/24/12 08:57 PM
09/24/12 08:57 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
And if you want the final degree of anal you seal everything up and pump 195 deg (or whatever your projected operating temp is) water thru the block while honing it.
Kevin
Re: Engine Builders. Torque Plate Question. [Re: Cab_Burge] #1309802
09/24/12 09:08 PM
09/24/12 09:08 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
this is what i have heard. heard of guys using two plates (one on each of course) torqued too, when they are very anal about bore.
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
