Best way to 2000 hp #1307616
09/20/12 06:42 PM
09/20/12 06:42 PM
Ky
moparmafia Offline OP
Ky
I was wondering what would be the best and most cost effective way to make 2000 hp with a big block mopar wedge. I know making that kind of power is not cheap at all but what would be the best route? I have seen prochargers site that claims 2400+ with an f3 or i was thinking twin turbos or could it be done with a predator motor on nos? i have an aluminum indy block and was thinking of which way to go. I was talking to a ford guy the other day and he said his mild 420 sbf with twin turbo makes 2300+ and he said the same cant be done with a wedge mopar. so any input or help would be greatly appreciated.
Re: Best way to 2000 hp [Re: moparmafia] #1307617
09/20/12 09:06 PM
09/20/12 09:06 PM
Delray beach, Florida
P
Performance Only Offline
P
it's really not that hard to do, just pick your poison when it comes to how your going to create boost and use good heads. B-1's, B-1mc or predators and enough boost will easily make 2000 HP. don't think for a moment though that you can skimp on the quality of any of the other parts that will go in it or you'll build it more than once.
machine shop owner and engine builder
Re: Best way to 2000 hp [Re: moparmafia] #1307618
09/20/12 09:44 PM
09/20/12 09:44 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Just nod and back away, UNLESS you have a bunch of money just to prove him wrong.
Re: Best way to 2000 hp [Re: moparmafia] #1307619
09/20/12 09:48 PM
09/20/12 09:48 PM
ohio
top comp Offline
top comp  Offline
ohio
best wat to 2000plus hp-- simple a good set of B-1s and a good blower
Re: Best way to 2000 hp [Re: moparmafia] #1307620
09/20/12 10:44 PM
09/20/12 10:44 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I stop listening when someone (whose car is not visible) says "twin turbo".
Boffin Emeritus
Re: Best way to 2000 hp [Re: moparmafia] #1307621
09/20/12 10:50 PM
09/20/12 10:50 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Copy what Marty Pearcy builds
Re: Best way to 2000 hp [Re: RodStRace] #1307622
09/20/12 10:52 PM
09/20/12 10:52 PM
Ky
Ky
I don't want to spend money just to prove him wrong i was seriously thinking about running 10.5 outlaw the same as him. thats when he told me mopars were ok to have back in the 60s and 70s but their not something you would want to build today and try to go fast.I was thinking of trying max ported b1 original heads and an f3 blower but i don't know if that would be enough head even with higher boost.
Re: Best way to 2000 hp [Re: fishy340] #1307623
09/20/12 10:55 PM
09/20/12 10:55 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
ford 2300 hp in a3000# mustang with all your ducks in a row should go 6.36 210 mph------ just saying
Re: Best way to 2000 hp [Re: moparmafia] #1307624
09/20/12 11:01 PM
09/20/12 11:01 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I don't believe the Predator heads fit a wedge block, so if your intending to use that, your stuck with B1's or Indy's....
And maybe one of these:
http://www.smreperformance.com/images/monty-myler-2020hp-engine2.jpg
Re: Best way to 2000 hp [Re: Dragula] #1307625
09/20/12 11:15 PM
09/20/12 11:15 PM
P
P
Predator heads are made for both Hemi and Wedge blocks.
Re: Best way to 2000 hp [Re: dodger mope] #1307626
09/21/12 12:44 AM
09/21/12 12:44 AM
Cab_Burge Online work
Cab_Burge  Online Work
I know a 10.5 Outlaw Mustang with a Mopar motor on alcholol that has gone 4.20 at 180 MPH + in the 1/8, 226 + MPH in the 1/4 so far on alcholol A well sorted out 550 C.I. Predator headed motor boosted on alcholol should run that good or better, if you can hook it
Re: Best way to 2000 hp [Re: Dragula] #1307627
09/21/12 12:50 AM
09/21/12 12:50 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Predators will fit Wedge or Hemi, they make both.
Re: Best way to 2000 hp [Re: Biginchmopar] #1307628
09/21/12 08:38 AM
09/21/12 08:38 AM
gregsdart Offline
gregsdart  Offline
If you are building to a set of class rules that restrict cubic inch, then you have to have very good heads to compete. Only the best will do. If your goal is to just get to 2,000 hp with any size shortblock, the bigger the motor the easier and cheaper it is. The parts required still have to handle the power, but less boost/more cubes is a lot easier to work with than small cubes/huge boost numbers. The higher the boost pressure, the more the intake air temp goes up and the tougher it is to get it back to where you need it. I don't know about cost, but the turbos are the most efficient, prochargers close behind, then twin screw blowers, and at the bottom of the heap is the GMC style blower. A lot of it depends on what you like to work with. My personal favorite is a twin screw. Not the most efficient, but they have great power over the whole rpm range and no lag like some turbos will have.
Re: Best way to 2000 hp [Re: gregsdart] #1307629
09/21/12 10:36 AM
09/21/12 10:36 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
My combo makes 2300 HP on 25 psi of boost . I think I got it figured out now . Last three passes were 6.832 , 6.834 , 6.780 and the car weighed 2950 at 209 to 212 for the MPH . The boost was ramped it at 2.3 seconds and this weekend I will try to have it all in at 1.4 this should give me better ET . It was doing a 4.44 to 4.46 and 168MPH in the 1/8 . Bringing boost in earlier will not make it so soggy in the front half .
You will not make this power with a Indy block , I already tried ..
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Best way to 2000 hp [Re: go green] #1307630
09/21/12 10:44 AM
09/21/12 10:44 AM
Dragula Offline
Dragula  Offline
As I recalled you moved the dowels out away from the cylinder bores...KB block now, correct?
Re: Best way to 2000 hp [Re: Dragula] #1307631
09/21/12 11:46 AM
09/21/12 11:46 AM
go green Offline
go green  Offline
Yes , they are moved away from the cylinder bores , with the 4.5 bore the o-ring gets real close to the stock dowl .
Re: Best way to 2000 hp [Re: go green] #1307632
09/21/12 12:26 PM
09/21/12 12:26 PM
Ky
Ky
so is the kb block just thicker in this area? I was told my indy block was good for 2000+ hp
Re: Best way to 2000 hp [Re: moparmafia] #1307633
09/21/12 12:56 PM
09/21/12 12:56 PM
go green Offline
go green  Offline
Stick your finger in the water transfer holes on the deck and feel the casting around the head bolt . They are not cast deep enough or big enough . With the stock 7/16 or if you go to 1/2 head studs there is only .750 thread engagement and no casting left to go deeper , it just goes nowhere . The thread cast is just stuck on the cylinder bore and 60% is hanging in the water jacket with no support . The KB is a solid deck with the water transfer port drilled the lower water gallery .
Re: Best way to 2000 hp [Re: moparmafia] #1307634
09/21/12 01:32 PM
09/21/12 01:32 PM
P
P
i wouldn't ever attempt 2000+ horsepower on a Indy block.
Re: Best way to 2000 hp [Re: Performance Only] #1307635
09/21/12 02:41 PM
09/21/12 02:41 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Being mid way through a Twin Turbo (4788's) fuel injected Hemi build, I can tell you this much . . . .
1) Work out your budget
2) Double the above
3) Add another 10% to the above, then you will be in the right ball park . . . .
Sure, I have heard of cheaper, more powerfull Mopar combos, but also hear a lot [Edited by Moparts - Family Friendly Site - Keep it clean] in the pub.
I could of possibly gone with cheaper parts, but then it gets into a vicous cycle
I am running a KB Block
