Broken trans cooler fitting in transmission, what to do #1306047
09/17/12 11:40 PM
09/17/12 11:40 PM
Fort Collins, Colorado
CoDart Offline OP
CoDart  Offline OP
I was going to put different styled fittings in this 727, and it broke. What can I do to fix it?
Re: Broken trans cooler fitting in transmission, what to do [Re: CoDart] #1306048
09/17/12 11:47 PM
09/17/12 11:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Remove it with an easyout. Then install a new fitting.
Re: Broken trans cooler fitting in transmission, what to do [Re: CoDart] #1306049
09/17/12 11:48 PM
09/17/12 11:48 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
EZ Out..
Re: Broken trans cooler fitting in transmission, what to do [Re: 1_WILD_RT] #1306050
09/18/12 02:54 AM
09/18/12 02:54 AM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
easy outs are junk, I tap in a torx bit and back it out, works every time.
Re: Broken trans cooler fitting in transmission, what to do [Re: cageman] #1306051
09/18/12 04:39 PM
09/18/12 04:39 PM
Weatherford Texas
Greg Ducato Offline
Greg Ducato  Offline
Weatherford Texas
Agreed, the easy out will just grind out the inner diameter of the brass, use the torx bit method.
Re: Broken trans cooler fitting in transmission, what to do [Re: cageman] #1306052
09/18/12 05:59 PM
09/18/12 05:59 PM
scratchnfotraction Offline
I use a square 4 edged ez out on those fittings when they break.
I learn something new here all the time.
thanks,I will try that torx bit trick next time I have a trans fitting broke.
Re: Broken trans cooler fitting in transmission, what to do [Re: scratchnfotraction] #1306053
09/18/12 06:33 PM
09/18/12 06:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, the spiral type EZ-Out will usually just spin in the brittle brass but the square type will work.
Re: Broken trans cooler fitting in transmission, what to do [Re: John_Kunkel] #1306054
09/18/12 10:46 PM
09/18/12 10:46 PM
CoDart Offline OP
CoDart  Offline OP
Ta daaaa!!!
Thanks for the tip! I just drilled it out to max size then pounded a torx in it and it came right out
