Re: Broken trans cooler fitting in transmission, what to do
[Re: cageman]
#1306051
09/18/12 04:39 PM
09/18/12 04:39 PM
Posts: 32 Weatherford Texas
Greg Ducato
Weatherford Texas
easy outs are junk, I tap in a torx bit and back it out, works every time.
Agreed, the easy out will just grind out the inner diameter of the brass, use the torx bit method.
[Re: cageman]
#1306052
09/18/12 05:59 PM
09/18/12 05:59 PM
Posts: 15,487 Florida
scratchnfotraction
I use a square 4 edged ez out on those fittings when they break.
I learn something new here all the time.
thanks,I will try that torx bit trick next time I have a trans fitting broke.
[Re: scratchnfotraction]
#1306053
09/18/12 06:33 PM
09/18/12 06:33 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Yep, the spiral type EZ-Out will usually just spin in the brittle brass but the square type will work.
