Help, I have a Holley 1050 kicking my tail #1305696
09/17/12 03:09 PM
09/17/12 03:09 PM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
Have run a 1050 Holley for years with good results, but let it sit for a year, and can't get it to idle clean. Floats are set right, and the needle and seats are holding, but idles rich, and seems to drip and flood the engine when I shut it down. Starts great when its cold, but hard starting after it has been run a while. Got the metering plates soaking now. Got any ideas? TIA
Re: Help, I have a Holley 1050 kicking my tail [Re: farmboy] #1305697
09/17/12 03:14 PM
09/17/12 03:14 PM
Southern IL.
jafr Offline
jafr  Offline
Southern IL.
Check the floats. Brass float could have a pin hole, nitrophyl could be heavy from soaking up fuel.
Re: Help, I have a Holley 1050 kicking my tail [Re: jafr] #1305698
09/17/12 05:16 PM
09/17/12 05:16 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Shoot some carb cleaner and air into the idle air bleeds sould be dirty. Do you run an air filter?
Re: Help, I have a Holley 1050 kicking my tail [Re: radar] #1305699
09/17/12 07:34 PM
09/17/12 07:34 PM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
I just soaked the metering blocks, checked for warpage, put in new brass floats, cleaned the air bleeds, and set the fuel level. Started great cold, idled pretty nice, but still a little rich, but acts flooded when you go to start in five minutes, Lots of gas vapor coming out of the front two barrels, after you kill the engine. Bad needle and seat?????
Re: Help, I have a Holley 1050 kicking my tail [Re: farmboy] #1305700
09/17/12 09:25 PM
09/17/12 09:25 PM
Cab_Burge Online work
Cab_Burge  Online Work
What type of fuel?, Race gas or ?
Re: Help, I have a Holley 1050 kicking my tail [Re: Cab_Burge] #1305701
09/17/12 10:42 PM
09/17/12 10:42 PM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
Running 91 octane pump gas
Re: Help, I have a Holley 1050 kicking my tail [Re: farmboy] #1305702
09/17/12 11:40 PM
09/17/12 11:40 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
so you say you are using pump gas.Which probably has ethinaul (sp) Which is hard on anything with some rubbers. If you have a power valve I would look there based on your symptoms.
JAKES AUTOMOTIVE
Re: Help, I have a Holley 1050 kicking my tail [Re: JAKE68] #1305703
09/18/12 05:26 AM
09/18/12 05:26 AM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
Just put in new 35 power valves a couple days ago.
Re: Help, I have a Holley 1050 kicking my tail [Re: farmboy] #1305704
09/18/12 06:35 AM
09/18/12 06:35 AM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
ccheck your set up...if it is dripping out the boosters you may have too much transition slot showing....take it off...turn it upside down...set the butterflies to show a small 'square' transition slot and put it back on...leave the idle speed screws alone from here and try to tune idle with the fuel screws...if you cant get it perfect try to adjust the rear idle srew just a little bit.....
Re: Help, I have a Holley 1050 kicking my tail [Re: farmboy] #1305705
09/18/12 10:46 AM
09/18/12 10:46 AM
Hobart,Indiana
MoparPitBull Offline
Hollywood
Hollywood
Hobart,Indiana
You say the carb sat-up for awhile...check o-ring on the primary needle and seat. If it looks suspect, swap it to the secondary and if booster starts dripping in rear you have pinpointed your problem.
Re: Help, I have a Holley 1050 kicking my tail [Re: bwhackd34] #1305706
09/18/12 09:06 PM
09/18/12 09:06 PM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
I think that was the problem. tried adjusting the rear enough to get it to idle clean, but then the rear drips. Biggest problem now is way too rich at idle.
Re: Help, I have a Holley 1050 kicking my tail [Re: farmboy] #1305707
09/19/12 12:26 PM
09/19/12 12:26 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
Great!....if you have adjustable bleeds go up on orifice size on the outside bleeds
