Re: Help, I have a Holley 1050 kicking my tail
[Re: radar]
#1305699
09/17/12 07:34 PM
09/17/12 07:34 PM
Posts: 391 kansas
farmboy
kansas
I just soaked the metering blocks, checked for warpage, put in new brass floats, cleaned the air bleeds, and set the fuel level. Started great cold, idled pretty nice, but still a little rich, but acts flooded when you go to start in five minutes, Lots of gas vapor coming out of the front two barrels, after you kill the engine. Bad needle and seat?????
[Re: farmboy]
#1305700
09/17/12 09:25 PM
09/17/12 09:25 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
What type of fuel?, Race gas or ?
[Re: farmboy]
#1305702
09/17/12 11:40 PM
09/17/12 11:40 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
so you say you are using pump gas.Which probably has ethinaul (sp) Which is hard on anything with some rubbers. If you have a power valve I would look there based on your symptoms.
JAKES AUTOMOTIVE
