how do you guys get to this weld #1302471
09/11/12 11:46 PM
09/11/12 11:46 PM
nc
E
earthmover Offline OP
E
nc
Re: how do you guys get to this weld [Re: earthmover] #1302472
09/11/12 11:48 PM
09/11/12 11:48 PM
nc
E
E
nc
really hate to cut the qrt. to finish just this little 3" weld..sorry bout all the ??? and post
Re: how do you guys get to this weld [Re: earthmover] #1302473
09/11/12 11:48 PM
09/11/12 11:48 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
VERY carefully!!!!!!!
Re: how do you guys get to this weld [Re: MIKES_DUSTER] #1302474
09/11/12 11:49 PM
09/11/12 11:49 PM
nc
E
E
nc
lol you funny mike.. hows that small block coming along???did you make it out this year???
Re: how do you guys get to this weld [Re: earthmover] #1302475
09/12/12 12:05 AM
09/12/12 12:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I believe you can get in there with the mig... run the
wire out before you start and run it hot with more
wire speed... it wont be pretty... in cases like this
you have you have to think ahead and work your way out
(I know you bought it this way)... plus in a case like
this it doesnt have to be 100% around
Re: how do you guys get to this weld [Re: MR_P_BODY] #1302476
09/12/12 12:11 AM
09/12/12 12:11 AM
nc
E
E
nc
thanks mr.p i was thinking of trying it that way ..but at the same time i was thinking if it would be ok to pass the cert when i need or get ready to..i will try it and if all fall grind and get someone else to do it.lol
Re: how do you guys get to this weld [Re: MR_P_BODY] #1302477
09/12/12 12:14 AM
09/12/12 12:14 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
does NHRA say 60% with gussets?
when i did mine- it aint pretty- but i switched to inner shield for the places i could not get the mig torch in. so i could do it from 2-3 inches. ugly but looked like it got penetration. I think i have maybe 4 inches through out the entire car that are flux core welded. Probably closer to 3 total inches.. just a few small sports here and there.
Re: how do you guys get to this weld [Re: 8urvette] #1302478
09/12/12 12:20 AM
09/12/12 12:20 AM
nc
E
E
nc
thanks that gives my hope ..lol i may be able to do this myself..
Re: how do you guys get to this weld [Re: earthmover] #1302479
09/12/12 01:19 AM
09/12/12 01:19 AM
Slow and No!!!!!! LOL!!!!! It is running,still need front tires and a few small things. Hows your BB coming along??
Re: how do you guys get to this weld [Re: MIKES_DUSTER] #1302480
09/12/12 01:23 AM
09/12/12 01:23 AM
nc
E
E
nc
big block is tog. just gotta put the swing pick up in it..thats it in my pics.. im using for mock up lol, trans is done, just working on the chassis and trying to get it finished and painted..
Re: how do you guys get to this weld [Re: earthmover] #1302481
09/12/12 01:43 AM
09/12/12 01:43 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
You need a big cup and gas screen, stick your tungsten out farther than normal (I'm guessing an inch should give you enough reach), and turn your gas up to like 45. Should be no problem
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: how do you guys get to this weld [Re: DemonDust] #1302482
09/12/12 01:52 AM
09/12/12 01:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
He's migging
Re: how do you guys get to this weld [Re: MR_P_BODY] #1302483
09/12/12 02:01 AM
09/12/12 02:01 AM
nc
E
E
nc
He's migging
Re: how do you guys get to this weld [Re: earthmover] #1302484
09/12/12 02:15 AM
09/12/12 02:15 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Sorry didn't see any mention of the weld method. I guess I just assumed since it was a cage it was gonna be tigged...
Note to self; Stop assuming!
SDG Motorsports
Re: how do you guys get to this weld [Re: DemonDust] #1302485
09/12/12 06:18 AM
09/12/12 06:18 AM
metro detroit
turner Offline
turner  Offline
metro detroit
If you could switch to stick and get piece of 3/32 7018 excalibur rod and run it downhill it would look better, thats my opinion........but then again I weld for a living and feel real comfortable stick welding
Re: how do you guys get to this weld [Re: turner] #1302486
09/12/12 07:04 AM
09/12/12 07:04 AM
Guitar Jones Online laugh2
Actually you can get a cage certified when it's just tacked.
I also believe that a 75% weld is acceptable if there is a gusset. But you need to check on that for certain
Re: how do you guys get to this weld [Re: Guitar Jones] #1302487
09/12/12 08:18 AM
09/12/12 08:18 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I think that i have herd this two.
Re: how do you guys get to this weld [Re: racerx] #1302488
09/12/12 08:37 AM
09/12/12 08:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I was told by 1 inspector it needed to be 80% but I
never seen a guy get out a tape to measure the diameter
and figure it... so its up to the inspectors discretion
Re: how do you guys get to this weld [Re: MR_P_BODY] #1302489
09/12/12 09:01 AM
09/12/12 09:01 AM
nc
E
E
nc
i have a stick welder also..
Re: how do you guys get to this weld [Re: earthmover] #1302490
09/12/12 09:33 AM
09/12/12 09:33 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Do you know any pipe fiter buddies? If so Ive used a very small 90 and 45 degree tig torch that should fin in there.
Contact them and see about having them run over and nail those little welds out for ya.
Ive used a torch just like this before for welding in very tight places on the job. I know you are migging this, but you can finishthe job with one of these and it wont get all globber boogered up.
