how do you guys get to this weld
#1302471
09/11/12 11:46 PM
09/11/12 11:46 PM
Posts: 2,449 nc
earthmover
nc
Re: how do you guys get to this weld
[Re: earthmover]
#1302475
09/12/12 12:05 AM
09/12/12 12:05 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I believe you can get in there with the mig... run the wire out before you start and run it hot with more wire speed... it wont be pretty... in cases like this you have you have to think ahead and work your way out (I know you bought it this way)... plus in a case like this it doesnt have to be 100% around
[Re: DemonDust]
#1302482
09/12/12 01:52 AM
09/12/12 01:52 AM
MR_P_BODY
You need a big cup and gas screen, stick your tungsten out farther than normal (I'm guessing an inch should give you enough reach), and turn your gas up to like 45. Should be no problem
He's migging
[Re: MR_P_BODY]
#1302483
09/12/12 02:01 AM
09/12/12 02:01 AM
Posts: 2,449 nc
earthmover
nc
He's migging
[Re: turner]
#1302486
09/12/12 07:04 AM
09/12/12 07:04 AM
Posts: 20,668 in a cattle trailer down by th...
Guitar Jones
Actually you can get a cage certified when it's just tacked.
I also believe that a 75% weld is acceptable if there is a gusset. But you need to check on that for certain
[Re: Guitar Jones]
#1302487
09/12/12 08:18 AM
09/12/12 08:18 AM
Posts: 4,076 Mo.
racerx
Mo.
I think that i have herd this two.
[Re: racerx]
#1302488
09/12/12 08:37 AM
09/12/12 08:37 AM
MR_P_BODY
I was told by 1 inspector it needed to be 80% but I never seen a guy get out a tape to measure the diameter and figure it... so its up to the inspectors discretion
