Re: Dana 60 issue,,I have no hair left!!!!
[Re: DoctorDiff]
#1300694
09/10/12 09:44 AM
09/10/12 09:44 AM
dartman366
Mt. Vernon, Ohio
Because Richmond does not make a standard (3 series) 4.10 ring and pinion, you probably have a 3 series spool. For some reason, Richmond has always listed this gear as "3 series", which is incorrect.
You need a spool designed for 4.56 - 7.17 gears, or any other brand of 4.10 gears, EXCEPT Richmond.
here is the moser part# 55D354 I believe that rea as a 35 spline series 4 carrier.
[Re: RUNCHARGER]
#1300695
09/10/12 11:41 AM
09/10/12 11:41 AM
Posts: 499 ohio
wj440
ohio
Ugh: I've never looked for backlash #'s I am not aware they are marked. What is on the head of the pinion? It should be 3.xvcx or + or -.
Sheldon
don't see those markings. The only markings that I see etched in is a 319 that tells me that this pinion gear goes with that ring gear. We did have to wait five months on this ring and pinion, because they were behind processing there 410 gears. Thanks
[Re: VernMotor]
#1300697
09/10/12 02:54 PM
09/10/12 02:54 PM
dartman366
Mt. Vernon, Ohio
It seems as tho Richmond (or someone) screwed up and packaged the wrong gear, plus it is also according to Richmond that they had some set's made up by one of their suppliers because this set does not have the Richmond marking's or the pinion depth and backlash etching's,,,,,,,we need a smiley pulling his hair out.
[Re: dartman366]
#1300698
09/10/12 03:11 PM
09/10/12 03:11 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
Can you say Richmond makes gears sets for other company without the Richmond logo stamped or etch in them Either way your still screwwed on your set, sorry.Whats next?
[Re: RUNCHARGER]
#1300702
09/10/12 10:41 PM
09/10/12 10:41 PM
Posts: 499 ohio
wj440
ohio
Don't tell me they're going to make you wait another 5 months for the correct gears.
Sheldon
No...6 months. He said it would be march.
[Re: wj440]
#1300703
09/10/12 10:51 PM
09/10/12 10:51 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
The big question I have is why didn't you just order from Doctordiff??? He is the most qualified vendor to get your parts from AND you get them right the first time every time Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Cab_Burge]
#1300704
09/11/12 04:22 AM
09/11/12 04:22 AM
dartman366
Mt. Vernon, Ohio
They probably do Cab but the tech guy said that some of these were made by Motive for them, and he thinks Motive boxed them wrong,,,I think they were the last set made on a friday before a holiday.
