Re: Dana 60 issue,,I have no hair left!!!! [Re: wj440] #1300692
09/10/12 12:19 AM
09/10/12 12:19 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Ugh: I've never looked for backlash #'s I am not aware they are marked. What is on the head of the pinion? It should be 3.xvcx or + or -.
Sheldon
Re: Dana 60 issue,,I have no hair left!!!! [Re: RUNCHARGER] #1300693
09/10/12 02:13 AM
09/10/12 02:13 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Dont forget about the 61 housing, its a 60 that the pinion offset was drilled different, the measurement are .125 off with those housings.
Re: Dana 60 issue,,I have no hair left!!!! [Re: DoctorDiff] #1300694
09/10/12 09:44 AM
09/10/12 09:44 AM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
Because Richmond does not make a standard (3 series) 4.10 ring and pinion, you probably have a 3 series spool. For some reason, Richmond has always listed this gear as "3 series", which is incorrect.
You need a spool designed for 4.56 - 7.17 gears, or any other brand of 4.10 gears, EXCEPT Richmond.
here is the moser part# 55D354 I believe that rea as a 35 spline series 4 carrier.
Re: Dana 60 issue,,I have no hair left!!!! [Re: RUNCHARGER] #1300695
09/10/12 11:41 AM
09/10/12 11:41 AM
ohio
W
wj440 Offline
wj440  Offline
W
ohio
Sheldon
don't see those markings. The only markings that I see etched in is a 319 that tells me that this pinion gear goes with that ring gear. We did have to wait five months on this ring and pinion, because they were behind processing there 410 gears. Thanks
Re: Dana 60 issue,,I have no hair left!!!! [Re: wj440] #1300696
09/10/12 02:34 PM
09/10/12 02:34 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well that look like the thin gear witch is the same as a stock gear. and that is what I run in my car. I can put 4.30 in it. I did at one time. but I have a yukon spool. I would think if you had a spool for a thick gear,,you would have a ton of back lash !
Re: Dana 60 issue,,I have no hair left!!!! [Re: VernMotor] #1300697
09/10/12 02:54 PM
09/10/12 02:54 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
It seems as tho Richmond (or someone) screwed up and packaged the wrong gear, plus it is also according to Richmond that they had some set's made up by one of their suppliers because this set does not have the Richmond marking's or the pinion depth and backlash etching's,,,,,,,we need a smiley pulling his hair out.
Re: Dana 60 issue,,I have no hair left!!!! [Re: dartman366] #1300698
09/10/12 03:11 PM
09/10/12 03:11 PM
Can you say Richmond makes gears sets for other company without the Richmond logo stamped or etch in them Either way your still screwwed on your set, sorry.Whats next?
Re: Dana 60 issue,,I have no hair left!!!! [Re: Cab_Burge] #1300699
09/10/12 06:24 PM
09/10/12 06:24 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
You ain't got no hair to pull out !
Re: Dana 60 issue,,I have no hair left!!!! [Re: wj440] #1300700
09/10/12 09:57 PM
09/10/12 09:57 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Don't tell me they're going to make you wait another 5 months for the correct gears.
Sheldon
Re: Dana 60 issue,,I have no hair left!!!! [Re: RUNCHARGER] #1300701
09/10/12 10:22 PM
09/10/12 10:22 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Go get a REAL set of spicer gears and then you know it will work.
Re: Dana 60 issue,,I have no hair left!!!! [Re: RUNCHARGER] #1300702
09/10/12 10:41 PM
09/10/12 10:41 PM
ohio
W
wj440 Offline
wj440  Offline
W
ohio
Sheldon
No...6 months. He said it would be march.
Re: Dana 60 issue,,I have no hair left!!!! [Re: wj440] #1300703
09/10/12 10:51 PM
09/10/12 10:51 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
The big question I have is why didn't you just order from Doctordiff???
He is the most qualified vendor to get your parts from AND you get them right the first time every time
Gus
64 Plymouth Savoy
Dana 60
Re: Dana 60 issue,,I have no hair left!!!! [Re: Cab_Burge] #1300704
09/11/12 04:22 AM
09/11/12 04:22 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
They probably do Cab but the tech guy said that some of these were made by Motive for them, and he thinks Motive boxed them wrong,,,I think they were the last set made on a friday before a holiday.
