Made an Air Pan today Results.....NEW BEST!!! #1299886
09/08/12 08:45 PM
09/08/12 08:45 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Finnaly got around to making one today.
Then off to the track tommorrow
Re: Made an Air Pan today [Re: Todd] #1299887
09/08/12 09:12 PM
09/08/12 09:12 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
At least you could have put some effort into it....
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Made an Air Pan today [Re: Todd] #1299888
09/08/12 09:17 PM
09/08/12 09:17 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Looks good,,hope it works for you too.
If you like drag racing, support your local track.
Re: Made an Air Pan today [Re: CHAPPER] #1299889
09/08/12 09:35 PM
09/08/12 09:35 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
That looks great! Nice work
Re: Made an Air Pan today [Re: Todd] #1299890
09/08/12 09:37 PM
09/08/12 09:37 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
You sir, need to do that for a living...
Re: Made an Air Pan today [Re: Hot 340] #1299891
09/08/12 10:25 PM
09/08/12 10:25 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
It wasn't that hard took a couple hours.
Got sheet of. 040 aluminum and some moroso foam.
The hold down is a handle off of the side of an aluminum harbor freight floor jack.
Found out that the foam cuts awesome with the bandsaw.
Re: Made an Air Pan today [Re: Todd] #1299892
09/09/12 07:25 AM
09/09/12 07:25 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
Nice:
Re: Made an Air Pan today [Re: Todd] #1299893
09/09/12 08:05 AM
09/09/12 08:05 AM
tboomer Offline
tboomer  Offline
Very nice!! What do you have for an intake?
Re: Made an Air Pan today [Re: tboomer] #1299894
09/09/12 08:34 AM
09/09/12 08:34 AM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Thanks everyone
The intake is a torquer.
Re: Made an Air Pan today [Re: Todd] #1299895
09/09/12 10:11 AM
09/09/12 10:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
How much room do you have from the top of your inlet
on the carb to the hood scoop and are you running a filter
Re: Made an Air Pan today [Re: MR_P_BODY] #1299896
09/09/12 10:42 AM
09/09/12 10:42 AM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
have about 3 1/2 inches.
Gonna try without a filter see how it does.
I'll know later today.
Re: Made an Air Pan today [Re: Todd] #1299897
09/09/12 10:49 AM
09/09/12 10:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I think you might have issues with the pressure differential
due to where the vents are located under the pan...
you might need to run a hose up into the pan area to
the vents(loop of hose attached to both vents with
a notch cut in the top)
Re: Made an Air Pan today [Re: MR_P_BODY] #1299898
09/09/12 10:51 AM
09/09/12 10:51 AM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Does that matter with an edelbrock Carb?
Re: Made an Air Pan today [Re: Todd] #1299899
09/09/12 10:59 AM
09/09/12 10:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If the carb has a vent(and I'm sure it does) then yes
it can make a difference... but thats dependent on
the differential between the top and bottom of the pan
Re: Made an Air Pan today [Re: MR_P_BODY] #1299900
09/09/12 11:31 AM
09/09/12 11:31 AM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Thanks for bringing that up. I completely forgot about that.
Re: Made an Air Pan today [Re: Todd] #1299901
09/09/12 06:19 PM
09/09/12 06:19 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Previous best at magnolia was a 7.47 at 90 MPH
Today with the only change was the airpan ran 7.30 at 94 mph
Re: Made an Air Pan today [Re: Todd] #1299902
09/09/12 06:25 PM
09/09/12 06:25 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Thats a good amount gained for a small investment.
Re: Made an Air Pan today [Re: Todd] #1299903
09/09/12 07:11 PM
09/09/12 07:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
BIG difference.... was the air similar... congrats
Re: Made an Air Pan today [Re: Todd] #1299904
09/09/12 07:22 PM
09/09/12 07:22 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
You had some nice cool air today too. Not to take anything away from the pan, I am sure that had something to do with it. Awesome.
383, Hemi 4-Speed, AlterKtion, D60
Re: Made an Air Pan today [Re: Crazy68Dart] #1299905
09/09/12 07:40 PM
09/09/12 07:40 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Before with the bad hot summer air it would run upper 7.50's
The previous best was with good air
