Made an Air Pan today Results.....NEW BEST!!!
#1299886
09/08/12 08:45 PM
09/08/12 08:45 PM
Posts: 1,377 Ohio
Todd
Ohio
Finnaly got around to making one today. Then off to the track tommorrow
Re: Made an Air Pan today
[Re: Hot 340]
#1299891
09/08/12 10:25 PM
09/08/12 10:25 PM
Posts: 1,377 Ohio
Todd
Ohio
You sir, need to do that for a living...
It wasn't that hard took a couple hours. Got sheet of. 040 aluminum and some moroso foam. The hold down is a handle off of the side of an aluminum harbor freight floor jack. Found out that the foam cuts awesome with the bandsaw.
[Re: tboomer]
#1299894
09/09/12 08:34 AM
09/09/12 08:34 AM
Posts: 1,377 Ohio
Todd
Ohio
Very nice!! What do you have for an intake?
Thanks everyone The intake is a torquer.
[Re: MR_P_BODY]
#1299896
09/09/12 10:42 AM
09/09/12 10:42 AM
Posts: 1,377 Ohio
Todd
Ohio
How much room do you have from the top of your inlet on the carb to the hood scoop and are you running a filter
have about 3 1/2 inches. Gonna try without a filter see how it does. I'll know later today.
[Re: Todd]
#1299897
09/09/12 10:49 AM
09/09/12 10:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I think you might have issues with the pressure differential due to where the vents are located under the pan... you might need to run a hose up into the pan area to the vents(loop of hose attached to both vents with a notch cut in the top)
[Re: Todd]
#1299899
09/09/12 10:59 AM
09/09/12 10:59 AM
MR_P_BODY
Does that matter with an edelbrock Carb?
If the carb has a vent(and I'm sure it does) then yes it can make a difference... but thats dependent on the differential between the top and bottom of the pan
[Re: MR_P_BODY]
#1299900
09/09/12 11:31 AM
09/09/12 11:31 AM
Posts: 1,377 Ohio
Todd
Ohio
Thanks for bringing that up. I completely forgot about that.
[Re: Todd]
#1299903
09/09/12 07:11 PM
09/09/12 07:11 PM
MR_P_BODY
Previous best at magnolia was a 7.47 at 90 MPH Today with the only change was the airpan ran 7.30 at 94 mph
BIG difference.... was the air similar... congrats
[Re: Crazy68Dart]
#1299905
09/09/12 07:40 PM
09/09/12 07:40 PM
Posts: 1,377 Ohio
Todd
Ohio
You had some nice cool air today too. Not to take anything away from the pan, I am sure that had something to do with it. Awesome.
Before with the bad hot summer air it would run upper 7.50's The previous best was with good air
