100 hp up garde Ray Barton/mopar crate Hemi #1299274
09/07/12 05:20 PM
09/07/12 05:20 PM
Toronto,Canada
W
wkeggenhoff Offline OP
W
Toronto,Canada
Anyone buy there new cam they have ?
2 versions
50 hp flat tappet cam and lifters
100 hp flat tappet, cam, lifters springs retainers, etc
Bolt in using same pushrods from the hyd cam.
Both streetable
69 dodge charger,528 Hemi,Keisler TKO 5spd, Mosier 60 rear end
Re: 100 hp up garde Ray Barton/mopar crate Hemi [Re: wkeggenhoff] #1299275
09/10/12 08:20 AM
09/10/12 08:20 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Ray Barton would just ask one the the Cam makers to make a cam to the specs he has choosen.
Since it says you live in Toronto, why not pick up the phone and call Tim Banning of FHO, for hemis only and talk to him 1-905-797-2459. He lives in Bewdley Ontario on Rice Lake just north of Port Hope Ontario so your drive to his shop is relatively short.
1971 HEMI E BODY REGISTRY
Re: 100 hp up garde Ray Barton/mopar crate Hemi [Re: hemicar1971] #1299276
09/10/12 09:51 PM
09/10/12 09:51 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I agree: You'd be crazy NOT to call Tim at FHO.
Sheldon
Re: 100 hp up garde Ray Barton/mopar crate Hemi [Re: RUNCHARGER] #1299277
09/11/12 11:46 AM
09/11/12 11:46 AM
GA
roadrunninMark Online sick
roadrunninMark  Online Sick
GA
Are the factory cams in the new hemi not rollers? If they are, are they hydraulic rollers? I don't know why someone would want to switch back to a flat tappet or solid roller, unless they are making a race engine.
Re: 100 hp up garde Ray Barton/mopar crate Hemi [Re: roadrunninMark] #1299278
09/11/12 01:53 PM
09/11/12 01:53 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I switched from a solid roller back to a flat tappet cam...Easier on parts.
Re: 100 hp up garde Ray Barton/mopar crate Hemi [Re: Dragula] #1299279
09/11/12 07:51 PM
09/11/12 07:51 PM
GA
GA
I agree Dragula.
What is the factory cam in the new gen 3?
Re: 100 hp up garde Ray Barton/mopar crate Hemi [Re: roadrunninMark] #1299280
09/11/12 07:56 PM
09/11/12 07:56 PM
Renton Washington
Triple Threat Offline
Renton Washington
I agree Dragula.
Hyd Roller
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 100 hp up garde Ray Barton/mopar crate Hemi [Re: Triple Threat] #1299281
09/11/12 07:58 PM
09/11/12 07:58 PM
GA
GA
Thanks Dustin, that is what I thought it was. I don't know why they won't make the new cams hyd. rollers then, be cheaper to reuse the lifters and not have the friction of a flat tappet?
Re: 100 hp up garde Ray Barton/mopar crate Hemi [Re: roadrunninMark] #1299282
09/13/12 11:30 AM
09/13/12 11:30 AM
Toronto,Canada
W
W
Toronto,Canada
AS FAR AS I KNOW THE RAY BARTON/MOPAR HEMIS USE ROLLER ROCKERS ONLY. IT CURRENTLY HAS A REG. HYD CAM IN NOW.TALLKED TO TIM BEFORE (FHO), HE SAYS I COULD USE A SOLID ROLLER FOR STREET, WOULD LIVE AS LONG AS SPRING PRESSURE KEPT IN CHECK.
HEARD A LOT OF BAD FEED BACK ON SOLID ROLLERS CRAPPING OUT ON STREET( LACK OF LUBE AT IDLE WAS TOLD)
TYIM SYAS ENGINE WOULD HAVE TO COME APRAT AND HAVE MACHINE WORK DONE IN ORDER TO INSTALL A HYD. ROLLER CAM(NEED MORE CLEARANCE IN LIFTER AREA FOR HYD ROLLER LIFTERS)
Re: 100 hp up garde Ray Barton/mopar crate Hemi [Re: wkeggenhoff] #1299283
09/13/12 09:36 PM
09/13/12 09:36 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
oiling at idle NOT a problem if you get solid roller lifters that oil the rollers and while you're at it convert to pushrod oiling too. A solid roller will work fine on the street with these parts.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 100 hp up garde Ray Barton/mopar crate Hemi [Re: HemiRick] #1299284
09/13/12 10:37 PM
09/13/12 10:37 PM
Dragula Offline
Dragula  Offline
Solid rollers are great when everything is mild....When you want to really wick it up though and still street it, your asking for issues.
Re: 100 hp up garde Ray Barton/mopar crate Hemi [Re: Dragula] #1299285
09/13/12 11:08 PM
09/13/12 11:08 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
He only needs a mild solid roller for the 100 HP he wants. Get the Hemi book by Rich Nedbal.
Take care,
Rick
Re: 100 hp up garde Ray Barton/mopar crate Hemi [Re: HemiRick] #1299286
09/14/12 07:52 AM
09/14/12 07:52 AM
Dragula Offline
Dragula  Offline
Not worth the money or the trouble...Barton will even tell you that with all the chinese crap out there right now. So unless you need a roller, its just money....
Sell you my old street cam and lifters.....
