100 hp up garde Ray Barton/mopar crate Hemi
#1299274
09/07/12 05:20 PM
09/07/12 05:20 PM
Posts: 73 Toronto,Canada
wkeggenhoff
Toronto,Canada
Anyone buy there new cam they have ? 2 versions 50 hp flat tappet cam and lifters 100 hp flat tappet, cam, lifters springs retainers, etc Bolt in using same pushrods from the hyd cam. Both streetable
69 dodge charger,528 Hemi,Keisler TKO 5spd, Mosier 60 rear end
Re: 100 hp up garde Ray Barton/mopar crate Hemi
[Re: wkeggenhoff]
#1299275
09/10/12 08:20 AM
09/10/12 08:20 AM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Ray Barton would just ask one the the Cam makers to make a cam to the specs he has choosen.
Since it says you live in Toronto, why not pick up the phone and call Tim Banning of FHO, for hemis only and talk to him 1-905-797-2459. He lives in Bewdley Ontario on Rice Lake just north of Port Hope Ontario so your drive to his shop is relatively short.
1971 HEMI E BODY REGISTRY
[Re: roadrunninMark]
#1299278
09/11/12 01:53 PM
09/11/12 01:53 PM
Posts: 12,393 Taxes & Virus's R-US, NY
Dragula
Are the factory cams in the new hemi not rollers? If they are, are they hydraulic rollers? I don't know why someone would want to switch back to a flat tappet or solid roller, unless they are making a race engine.
I switched from a solid roller back to a flat tappet cam...Easier on parts.
#1299282
09/13/12 11:30 AM
09/13/12 11:30 AM
wkeggenhoff
Toronto,Canada
AS FAR AS I KNOW THE RAY BARTON/MOPAR HEMIS USE ROLLER ROCKERS ONLY. IT CURRENTLY HAS A REG. HYD CAM IN NOW.TALLKED TO TIM BEFORE (FHO), HE SAYS I COULD USE A SOLID ROLLER FOR STREET, WOULD LIVE AS LONG AS SPRING PRESSURE KEPT IN CHECK. HEARD A LOT OF BAD FEED BACK ON SOLID ROLLERS CRAPPING OUT ON STREET( LACK OF LUBE AT IDLE WAS TOLD) TYIM SYAS ENGINE WOULD HAVE TO COME APRAT AND HAVE MACHINE WORK DONE IN ORDER TO INSTALL A HYD. ROLLER CAM(NEED MORE CLEARANCE IN LIFTER AREA FOR HYD ROLLER LIFTERS)
[Re: wkeggenhoff]
#1299283
09/13/12 09:36 PM
09/13/12 09:36 PM
Posts: 4,848 Memphis
HemiRick
Memphis
oiling at idle NOT a problem if you get solid roller lifters that oil the rollers and while you're at it convert to pushrod oiling too. A solid roller will work fine on the street with these parts.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1299284
09/13/12 10:37 PM
09/13/12 10:37 PM
Dragula
Solid rollers are great when everything is mild....When you want to really wick it up though and still street it, your asking for issues.
