Re: Crank pulley w/ Fluid Damper harmonic balancer
[Re: PRPLHAZ]
#1297300
09/05/12 11:11 AM
09/05/12 11:11 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
The face is flush. With out taking any measurements, it looks like it is pushing the pulley out further, which explains why there are 10 washers spacing my alternator?
I think with a flush face you will need a hemi $$ pulley
[Re: hemicop]
#1297304
09/05/12 02:56 PM
09/05/12 02:56 PM
JohnRR
U.S.S.A.
I had a ximiliar problem. MArch was completlely useless, so I resorted to a single groove pulley taken off a '66 B-body 318 Coronet----problem solved
Does the poly 318 use shallower pulleys ?
[Re: JohnRR]
#1297306
09/05/12 03:02 PM
09/05/12 03:02 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Dont think so. Im thinking I tried a polly pulley with a pile of factory pullys I tried on my ATI damper on the Demon.
I ended up useing a pulley from DMI, or something like that from mancini racing and it worked with very lettle shimming to align it up.
http://chucker54.stores.yahoo.net/34bicrshpude.html
[Re: Moparnut426]
#1297307
09/06/12 09:31 AM
09/06/12 09:31 AM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Usually the March pulleys work.My kid sold one of the two he had to a member and it worked perfect.As for being underdrive we both run them on our BBs and have had no charging problesm or cooling problems.I think he still has one new one in the garage.Cant remeember if its 1 or 2 groove.Our setups have been on at least 10 years and both are street driven.Rocky
Chrysler Firepower
[Re: therocks]
#1297308
09/06/12 05:55 PM
09/06/12 05:55 PM
Posts: 329 Frederick, MD
moparguy1967
Frederick, MD
I having the same issue with finding a crank pulley. I just call March, and spoke with someone in their tech dept. he said to measure from the inside face of the dampner to the face of the water pump snout. Then let them know what the offset is. They have a few different pulley that may work.
