Crank pulley w/ Fluid Damper harmonic balancer #1297296
09/04/12 02:56 PM
09/04/12 02:56 PM
Waterford, MI
PRPLHAZ Offline OP
PRPLHAZ  Offline OP
Waterford, MI
Will a stock crank pulley work with the Fluid Damper or does it require a custom pulley? It currently has an aluminum single groove under-drive pulley & I noticed there were a lot of washers on the alternator bracket so it has me wondering. I pulled it out of a car with manual steering & want to put it in a car with power steering so I need a crank pulley with two grooves.
Re: Crank pulley w/ Fluid Damper harmonic balancer [Re: PRPLHAZ] #1297297
09/04/12 04:23 PM
09/04/12 04:23 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Does it have a flush face or a recessed face ?
Re: Crank pulley w/ Fluid Damper harmonic balancer [Re: JohnRR] #1297298
09/04/12 07:02 PM
09/04/12 07:02 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
JohnRR sold me a recessed fluid damper for a bb stroker I built and installed in a friends car. It worked perfect with a complete stock pulley/bracket system.
Re: Crank pulley w/ Fluid Damper harmonic balancer [Re: JohnRR] #1297299
09/05/12 10:01 AM
09/05/12 10:01 AM
Waterford, MI
PRPLHAZ Offline OP
PRPLHAZ  Offline OP
Waterford, MI
The face is flush. With out taking any measurements, it looks like it is pushing the pulley out further, which explains why there are 10 washers spacing my alternator?
Re: Crank pulley w/ Fluid Damper harmonic balancer [Re: PRPLHAZ] #1297300
09/05/12 11:11 AM
09/05/12 11:11 AM
JohnRR Offline
JohnRR  Offline
I think with a flush face you will need a hemi $$ pulley
Re: Crank pulley w/ Fluid Damper harmonic balancer [Re: PRPLHAZ] #1297301
09/05/12 11:40 AM
09/05/12 11:40 AM
AndyF Offline
AndyF  Offline
March has pulleys for the flush face Fluidamper.
Re: Crank pulley w/ Fluid Damper harmonic balancer [Re: PRPLHAZ] #1297302
09/05/12 12:10 PM
09/05/12 12:10 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
I had a ximiliar problem. MArch was completlely useless, so I resorted to a single groove pulley taken off a '66 B-body 318 Coronet----problem solved
Re: Crank pulley w/ Fluid Damper harmonic balancer [Re: hemicop] #1297303
09/05/12 12:17 PM
09/05/12 12:17 PM
west palm beach, florida
modelmakerinc Offline
also Keep in mind the MARCH crank pulleys are underdriven (SMALLER DIA) and dont turn the altenator fast enough.
DAMHIK
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Crank pulley w/ Fluid Damper harmonic balancer [Re: hemicop] #1297304
09/05/12 02:56 PM
09/05/12 02:56 PM
JohnRR Offline
JohnRR  Offline
Does the poly 318 use shallower pulleys ?
Re: Crank pulley w/ Fluid Damper harmonic balancer [Re: AndyF] #1297305
09/05/12 03:01 PM
09/05/12 03:01 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
my stock pulley worked but I have a "recessed" face damper.
Coming soon!!!!
Re: Crank pulley w/ Fluid Damper harmonic balancer [Re: JohnRR] #1297306
09/05/12 03:02 PM
09/05/12 03:02 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Dont think so. Im thinking I tried a polly pulley with a pile of factory pullys I tried on my ATI damper on the Demon.
I ended up useing a pulley from DMI, or something like that from mancini racing and it worked with very lettle shimming to align it up.
http://chucker54.stores.yahoo.net/34bicrshpude.html
Re: Crank pulley w/ Fluid Damper harmonic balancer [Re: Moparnut426] #1297307
09/06/12 09:31 AM
09/06/12 09:31 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Usually the March pulleys work.My kid sold one of the two he had to a member and it worked perfect.As for being underdrive we both run them on our BBs and have had no charging problesm or cooling problems.I think he still has one new one in the garage.Cant remeember if its 1 or 2 groove.Our setups have been on at least 10 years and both are street driven.Rocky
Chrysler Firepower
Re: Crank pulley w/ Fluid Damper harmonic balancer [Re: therocks] #1297308
09/06/12 05:55 PM
09/06/12 05:55 PM
Frederick, MD
moparguy1967 Offline
Frederick, MD
I having the same issue with finding a crank pulley. I just call March, and spoke with someone in their tech dept. he said to measure from the inside face of the dampner to the face of the water pump snout. Then let them know what the offset is. They have a few different pulley that may work.
