ladder bar set-up ????
#1295922
09/02/12 09:43 PM
09/02/12 09:43 PM
Posts: 1,030 ohio
67mprfan
ohio
Hi guys who ladder bar set-up would you use and why, my car is currently set-up with a leaf link system and is already backhalfed planning ahead for winter upgrade......unless someone can tell me how to get this thing to 60ft better 1.50 is the best,,,,,,,Thanks....btw the way use leaf springs or coilovers
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
Re: ladder bar set-up ????
[Re: 67mprfan]
#1295923
09/02/12 10:22 PM
09/02/12 10:22 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I really like the newest design Outlaw bars. Much thicker lower bar, more adjustability for pinion angle changes. I went from S/S leafs with spring clamps and a snubber, to ladder bar and coilovers. Best change I ever made.
[image][/image]
[Re: 67mprfan]
#1295924
09/03/12 02:11 AM
09/03/12 02:11 AM
Posts: 43,315 Bend,OR USA
Cab_Burge
My car(3450 lb Duster, 727 with the Mopar 2.77 low gear set, Dana 60 wth 4.10 gears with Strange Engr 35 spline spool and axels,Oregon pump gas through the mufflers with the air cleaner on ![](/ubbthreads/images/graemlins/boogie.gif) ) ran a 1.394 60 ft and 10.01 at 132. MPH and another 1.401 with a 10.04 at 131.9 MPH this weekend with 1/4 Max ladder bars and Strange Engr. double adjustable coil overs with 150 lb springs, extension set at 5 clicks form dead soft and 4 clicks on the compression, 10.5x31x15W M/T ET drag slicks, there is more left in it, I need to test it some more and try the different settings on the shocks on a good track ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
[Re: duster408]
#1295932
09/03/12 11:20 PM
09/03/12 11:20 PM
dartman366
Mt. Vernon, Ohio
S&W double adjustable ladder bars and QA-1 single adjustable coil overs,, mid to upper 1.30 60ft's, at 3170# good price and good quality and they just plain work. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 67mprfan]
#1295934
09/03/12 11:57 PM
09/03/12 11:57 PM
Posts: 1,030 ohio
67mprfan
ohio
here a couple of pics of what i have now
[Re: 67mprfan]
#1295938
09/04/12 03:24 PM
09/04/12 03:24 PM
Cab_Burge
After looking at your pictures I would convert it to a 4 link with coil overs and a panhard bar or diagonal link to locate the rear end on the side to side location. You will see a gain on the coil overs versus your current set up, make sure and buy a good set of externally adjsutable coil overs with long enough travel to make the car ride and respond well to the changes, like many things in life, longer is better than shorter ![](/ubbthreads/images/graemlins/image_294343.gif) My coil overs are 16.5 inches end to end extended with around seven inches of travel, mine is a street car so keep that in mind. Mine go through the trunk floor for the upper mounts and are mounted onto the roll bar down bars in the trunk, no bending or signs of stress to them so far, six yeas on the street and strip, 300 to 400 passes and 1300 street miles or so ![](/ubbthreads/images/graemlins/shruggy.gif) O I use to drive another Duster with single adjustable AVO brand coil over shocks that had three inches of travel ![](/ubbthreads/images/graemlins/down.gif) it was a foot brake car and it would top the rear shocks out on the starting line when foot stalling it above 3000 RPM ![](/ubbthreads/images/graemlins/shruggy.gif) My message is to get coil over shocks with enough travel to use on your car ![](/ubbthreads/images/graemlins/thumbs.gif) I have 150 rate springs, some racers like 130 lb rate on there coil over cars, mine work fine for me, maybe they should be softer ![](/ubbthreads/images/graemlins/shruggy.gif) IHTHs ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Cab_Burge]
#1295939
09/04/12 04:19 PM
09/04/12 04:19 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i dont know jack sh%$ but the way i see your setup, it looks like an endless instant center. that is the same suspension pro stocks used in the 70s and it worked. i would lower the top bar a hole, maybe raise the spring eye a hole and work with what you have before spending the money on changing it. your car is not really that fast plus you have a huge tire on the back. i dont think ladders would pick you up that much
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1295940
09/04/12 06:00 PM
09/04/12 06:00 PM
Posts: 4,101 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Well I read the original post this AM and I was thinking the exact same thing!...EVERYTHING Sixpac said. You have some decent pieces in that motor and at 3000lbs with driver SOMETHING ELSE is wrong. If everything looks safe under the car e.g.- weld integrity etc...I would only put a good pair of shocks on it. Maybe D.A. Strange without the coilovers or even the adj Rancheros. That MPH reflects about flywheel 525 HP. I'd suggest some of the more frequent oversites; 1)Hoodscoop and/or sealing problem 2)Carb improperly adjusted 3)What sparkplugs and gap AND wires? AND ignition? You'd be surprised how much ET/MPH you can loose from those 3 alone.
