ladder bar set-up ???? #1295922
09/02/12 09:43 PM
09/02/12 09:43 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
Hi guys who ladder bar set-up would you use and why, my car is currently set-up with a leaf link system and is already backhalfed planning ahead for winter upgrade......unless someone can tell me how to get this thing to 60ft better 1.50 is the best,,,,,,,Thanks....btw the way use leaf springs or coilovers
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: ladder bar set-up ???? [Re: 67mprfan] #1295923
09/02/12 10:22 PM
09/02/12 10:22 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I really like the newest design Outlaw bars. Much thicker lower bar, more adjustability for pinion angle changes. I went from S/S leafs with spring clamps and a snubber, to ladder bar and coilovers. Best change I ever made.
[image][/image]
Re: ladder bar set-up ???? [Re: 67mprfan] #1295924
09/03/12 02:11 AM
09/03/12 02:11 AM
My car(3450 lb Duster, 727 with the Mopar 2.77 low gear set, Dana 60 wth 4.10 gears with Strange Engr 35 spline spool and axels,Oregon pump gas through the mufflers with the air cleaner on ) ran a 1.394 60 ft and 10.01 at 132. MPH and another 1.401 with a 10.04 at 131.9 MPH this weekend with 1/4 Max ladder bars and Strange Engr. double adjustable coil overs with 150 lb springs, extension set at 5 clicks form dead soft and 4 clicks on the compression, 10.5x31x15W M/T ET drag slicks, there is more left in it, I need to test it some more and try the different settings on the shocks on a good track
Re: ladder bar set-up ???? [Re: Cab_Burge] #1295925
09/03/12 02:19 AM
09/03/12 02:19 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
My car 3400# 70 Dart, 1.402 60ft, 6.28@109.12 9.92@133 on super stock springs, Alston double ajustable ladder bars, 83/4, comp engineering 3-way shocks with housing floaters..
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: ladder bar set-up ???? [Re: Wicked49670dart] #1295926
09/03/12 03:11 AM
09/03/12 03:11 AM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
Our car 1.28-60' 9.57@140+ competition eng. ladder bars with strange coil overs.
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: ladder bar set-up ???? [Re: 67mprfan] #1295927
09/03/12 10:18 AM
09/03/12 10:18 AM
tboomer Online work
tboomer  Online Work
What is the rest of your combo? My leaf springs were shot and I was thinking of going to the Cal-Trac system under my 64. Jimmy Rickman talked me out of that and advised the Alston ladder bar setup. He did a great job of putting it in and I am very happy with it. My best 60' was a 1.385 and it usually runs in the 1.40-1.41 range...
Re: ladder bar set-up ???? [Re: tboomer] #1295928
09/03/12 09:48 PM
09/03/12 09:48 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
440 .055 over stock stroke
indy ez-1 heads and intake w/1050carb
660 lift cam 1.5 rockers
727 8in converter done by lenny 5400 stall
d60 4.56 gears 32 x 14x 15 tires
weight 3030 with me in it
best so far is 10.51 if i can get 60ft downs i be happy
Re: ladder bar set-up ???? [Re: 67mprfan] #1295929
09/03/12 10:04 PM
09/03/12 10:04 PM
duster408 Offline
duster408  Offline
Id definitely go with the ladder bar and coil over setup. The 60's will be more consistent. I have a 2900 lb duster small block with 1.30 60 ft. My 60s vary about .004 in a day
Re: ladder bar set-up ???? [Re: duster408] #1295930
09/03/12 10:09 PM
09/03/12 10:09 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
who's set up are you using?
Re: ladder bar set-up ???? [Re: 67mprfan] #1295931
09/03/12 10:30 PM
09/03/12 10:30 PM
duster408 Offline
duster408  Offline
Competition engineering ladder link with qa1 coilovers.
Re: ladder bar set-up ???? [Re: duster408] #1295932
09/03/12 11:20 PM
09/03/12 11:20 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
S&W double adjustable ladder bars and QA-1 single adjustable coil overs,, mid to upper 1.30 60ft's, at 3170# good price and good quality and they just plain work.
Re: ladder bar set-up ???? [Re: duster408] #1295933
09/03/12 11:23 PM
09/03/12 11:23 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
i been looking at theirs and chris alston, since my car has already been back halved im thinking it shouldn't be to hard to change over
Re: ladder bar set-up ???? [Re: 67mprfan] #1295934
09/03/12 11:57 PM
09/03/12 11:57 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
here a couple of pics of what i have now
Re: ladder bar set-up ???? [Re: 67mprfan] #1295935
09/03/12 11:58 PM
09/03/12 11:58 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
another 1
Re: ladder bar set-up ???? [Re: 67mprfan] #1295936
09/04/12 12:00 AM
09/04/12 12:00 AM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
nutter 1
Re: ladder bar set-up ???? [Re: 67mprfan] #1295937
09/04/12 12:01 AM
09/04/12 12:01 AM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
last 1
Re: ladder bar set-up ???? [Re: 67mprfan] #1295938
09/04/12 03:24 PM
09/04/12 03:24 PM
After looking at your pictures I would convert it to a 4 link with coil overs and a panhard bar or diagonal link to locate the rear end on the side to side location. You will see a gain on the coil overs versus your current set up, make sure and buy a good set of externally adjsutable coil overs with long enough travel to make the car ride and respond well to the changes, like many things in life, longer is better than shorter My coil overs are 16.5 inches end to end extended with around seven inches of travel, mine is a street car so keep that in mind. Mine go through the trunk floor for the upper mounts and are mounted onto the roll bar down bars in the trunk, no bending or signs of stress to them so far, six yeas on the street and strip, 300 to 400 passes and 1300 street miles or so O I use to drive another Duster with single adjustable AVO brand coil over shocks that had three inches of travel it was a foot brake car and it would top the rear shocks out on the starting line when foot stalling it above 3000 RPM My message is to get coil over shocks with enough travel to use on your car I have 150 rate springs, some racers like 130 lb rate on there coil over cars, mine work fine for me, maybe they should be softer IHTHs
Re: ladder bar set-up ???? [Re: Cab_Burge] #1295939
09/04/12 04:19 PM
09/04/12 04:19 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i dont know jack sh%$ but the way i see your setup, it looks like an endless instant center. that is the same suspension pro stocks used in the 70s and it worked. i would lower the top bar a hole, maybe raise the spring eye a hole and work with what you have before spending the money on changing it. your car is not really that fast plus you have a huge tire on the back. i dont think ladders would pick you up that much
Re: ladder bar set-up ???? [Re: sixpackgut] #1295940
09/04/12 06:00 PM
09/04/12 06:00 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Well I read the original post this AM and I was thinking the exact same thing!...EVERYTHING Sixpac said. You have some decent pieces in that motor and at 3000lbs with driver SOMETHING ELSE is wrong. If everything looks safe under the car e.g.- weld integrity etc...I would only put a good pair of shocks on it. Maybe D.A. Strange without the coilovers or even the adj Rancheros. That MPH reflects about flywheel 525 HP. I'd suggest some of the more frequent oversites;
1)Hoodscoop and/or sealing problem
2)Carb improperly adjusted
3)What sparkplugs and gap AND wires? AND ignition?
You'd be surprised how much ET/MPH you can loose from those 3 alone.
Re: ladder bar set-up ???? [Re: HardcoreB] #1295941
09/04/12 06:48 PM
09/04/12 06:48 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
If you ask me.. the stall on that converter is kind of high. 5400 for a big block car..
