70 RR air grabber fire wall
#1294204
08/30/12 03:38 PM
08/30/12 03:38 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Ok bought a 70 with original air grabber. There are 2 holes in the firewall. The one closest to the middle had the 3 hole gromit in it. But the one closest to the middle looks like someone drilled it and the one on the right side of the firewall looks more factory with a rolled edge. Which is correct and is the other one factory or just drilled. If factory what goes there?
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
Re: 70 RR air grabber fire wall
[Re: MOPARMIKE69]
#1294205
08/30/12 05:41 PM
08/30/12 05:41 PM
Posts: 3,524 Lansing, MI
70gtx440dana
Lansing, MI
Both locations were used for air grabber hoses. It is mfg. plant dependent. Where was your car built?
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#1294206
08/30/12 05:45 PM
08/30/12 05:45 PM
70gtx440dana
Lansing, MI
Here is a photo of my LA built RR firewall.
[Re: 70gtx440dana]
#1294207
08/30/12 05:46 PM
08/30/12 05:46 PM
70gtx440dana
Lansing, MI
Here is a photo of a Lynch Rd. built Super Bee.
[Re: flypaper]
#1294211
08/31/12 09:46 AM
08/31/12 09:46 AM
MOPARMIKE69
Nashville, TN
It is a St Louis built car and the build date was 9/23/69. thanks for your help on this and for your pics.
[Re: 70gtx440dana]
#1294212
08/31/12 09:50 AM
08/31/12 09:50 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
This car would have the hole in that location because it used the 69 style ramcharger ductwork not the pop up air grabber.
[Re: gtx6970]
#1294218
08/31/12 02:42 PM
08/31/12 02:42 PM
MOPARMIKE69
Nashville, TN
So is it even conceivable that since it was a way early car and that the pop up airgrabber was new that they drilled both holes. One for the manual by mistake and then one for the pop up in the correct spot? Since in the pictures of the St Louis cars all have the hole not by the voltage regulator and the hole by the voltage reg was for the manual one? I mean why would anyone drill another hole over by the voltage regulator with the correct one already there? The correct one was even drilled into the dimple creating the beveled edge. One more question is the hole for the manual air grabber on the R/t in a dimple or just in the firewall?
[Re: MOPARMIKE69]
#1294219
08/31/12 03:25 PM
08/31/12 03:25 PM
JohnRR
U.S.S.A.
It's in a Dimple
