70 RR air grabber fire wall #1294204
08/30/12 03:38 PM
08/30/12 03:38 PM
Nashville, TN
MOPARMIKE69 Offline OP
Nashville, TN
Ok bought a 70 with original air grabber. There are 2 holes in the firewall. The one closest to the middle had the 3 hole gromit in it. But the one closest to the middle looks like someone drilled it and the one on the right side of the firewall looks more factory with a rolled edge.
Which is correct and is the other one factory or just drilled. If factory what goes there?
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 70 RR air grabber fire wall [Re: MOPARMIKE69] #1294205
08/30/12 05:41 PM
08/30/12 05:41 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Both locations were used for air grabber hoses. It is mfg. plant dependent. Where was your car built?
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 RR air grabber fire wall [Re: 70gtx440dana] #1294206
08/30/12 05:45 PM
08/30/12 05:45 PM
Lansing, MI
Lansing, MI
Here is a photo of my LA built RR firewall.
Re: 70 RR air grabber fire wall [Re: 70gtx440dana] #1294207
08/30/12 05:46 PM
08/30/12 05:46 PM
Lansing, MI
Lansing, MI
Here is a photo of a Lynch Rd. built Super Bee.
Re: 70 RR air grabber fire wall [Re: MOPARMIKE69] #1294208
08/30/12 05:49 PM
08/30/12 05:49 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
My FEB '70 Los Angeles built GTX was under the voltage regulator. What plant & when was your Road Runner built?
Re: 70 RR air grabber fire wall [Re: 6bblgt] #1294209
08/30/12 06:16 PM
08/30/12 06:16 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Here's an OCT. '69 St. Louis assembled N96 Road Runner. Both holes should not be there, looks like someone added one because they thought it belonged in the other location.
Re: 70 RR air grabber fire wall [Re: 6bblgt] #1294210
08/31/12 12:21 AM
08/31/12 12:21 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
Re: 70 RR air grabber fire wall [Re: flypaper] #1294211
08/31/12 09:46 AM
08/31/12 09:46 AM
Nashville, TN
Nashville, TN
It is a St Louis built car and the build date was 9/23/69. thanks for your help on this and for your pics.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: 70 RR air grabber fire wall [Re: 70gtx440dana] #1294212
08/31/12 09:50 AM
08/31/12 09:50 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This car would have the hole in that location because it used the 69 style ramcharger ductwork not the pop up air grabber.
Re: 70 RR air grabber fire wall [Re: JohnRR] #1294213
08/31/12 11:46 AM
08/31/12 11:46 AM
Ontario, Canada
B5Superbird Offline
B5Superbird  Offline
Ontario, Canada
Here is my St. Louis built 70 Runner factory N96..
Re: 70 RR air grabber fire wall [Re: B5Superbird] #1294214
08/31/12 01:11 PM
08/31/12 01:11 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Lynch Road car.
Re: 70 RR air grabber fire wall [Re: JohnRR] #1294215
08/31/12 01:12 PM
08/31/12 01:12 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
That was my thought as well, John. My N96 'Bee has the hole in that location too
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 70 RR air grabber fire wall [Re: gtx6970] #1294216
08/31/12 01:13 PM
08/31/12 01:13 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Tag for same
Re: 70 RR air grabber fire wall [Re: gtx6970] #1294217
08/31/12 02:25 PM
08/31/12 02:25 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Bill, looks like they missed the dimple for the hole & I don't think that tag is an original - A01/SPDs are in the mid-13xxxxs.
Re: 70 RR air grabber fire wall [Re: gtx6970] #1294218
08/31/12 02:42 PM
08/31/12 02:42 PM
Nashville, TN
Nashville, TN
So is it even conceivable that since it was a way early car and that the pop up airgrabber was new that they drilled both holes. One for the manual by mistake and then one for the pop up in the correct spot?
Since in the pictures of the St Louis cars all have the hole not by the voltage regulator and the hole by the voltage reg was for the manual one?
I mean why would anyone drill another hole over by the voltage regulator with the correct one already there? The correct one was even drilled into the dimple creating the beveled edge.
One more question is the hole for the manual air grabber on the R/t in a dimple or just in the firewall?
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: 70 RR air grabber fire wall [Re: MOPARMIKE69] #1294219
08/31/12 03:25 PM
08/31/12 03:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's in a Dimple
Re: 70 RR air grabber fire wall [Re: JohnRR] #1294220
08/31/12 03:36 PM
08/31/12 03:36 PM
Nashville, TN
Nashville, TN
It's in a Dimple
Yep I went out and checked and both my holes are in dimples and both are exactly the same diameter. Oh well no way to prove what happened so I guess I will just put a rubber plug in the one by the volt. reg.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: 70 RR air grabber fire wall [Re: MOPARMIKE69] #1294221
08/31/12 03:56 PM
08/31/12 03:56 PM
USA
b54406barrel Offline
USA
Sorry this is such a bad picture but it was quite sometime ago & a 1MB kodak camera. The plant was 'G' and the hole was behind the regulator for the ag hoses. I think it looks like B14 on the date.
Re: 70 RR air grabber fire wall [Re: b54406barrel] #1294222
08/31/12 03:59 PM
08/31/12 03:59 PM
USA
USA
