Weight reduction showed up in new PB #1293893
08/29/12 07:22 PM
08/29/12 07:22 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
I have been chasing a little more et recently,to put me closer to the pointy end in my racing class.
After farting around with induction and cam etc i finally got down to the nitty gritty - weight.
2 weeks ago i got some new hoosiers(275/60R15) and whilst i was at i weighed up some wheels/tyre combos
Weld 15x8 with Hoosier 9.0x30R15 (lite weight) 14.6kg
Torquethrust 2 15x10 MT 295/65R15 25.75kg
Centreline Qualifier 15x8 Hoosier 275/60R15 17.3kg (38.06 lbs)
Centreline Qualifier 15x8 R/stone 255/70R15 21.9kg
Centreline Qualifier 15x4 H/cook 185/80R15 14.2kg
In for a penny in for a pound i thought weigh the rear seat,my mates keep saying pull it out it's dead weight . 20.29kg (44.74 lbs)
Maybe i should race with less uel in the tank,stock with sump.OK instead of starting with about 60 litres (15Gal) lets try around 30 litres,there's around 21kg (46lbs)
Went to the street meet last night.These have not much prep and around 180 cars run mostly street tyres.
For the time of year it was quite mild,high 60's low 70's temp.Using my predicter weather station it sat between 1345 and 1500DA all night.
Predicter called 11.15-17 all night.
1st pass - 1.542 sixty for a [Email]11.182@119.38[/Email] but good mph
2nd pass - 1.525 sixty for a [Email]11.109@119.80[/Email] thought the bonnet lifted a little high
3rd pass 1.517 sixty for a [Email]11.109@119.36[/Email]
PB in sixty footer
Full track oil down 50 minute clean up .Darn thought the track may go too cold
4th pass - 1.511 sixty for a [Email]11.084@119.69[/Email] PB in 60' and ET
The weight reduction was around 80 - 90 lbs to give an et reduction of 6 - 8 hundredths.
Well worth the effort.Unfortunately we are now moving out from the killer cold dry air into spring.Now to try the Hoosier lite weight 30x9 Weld wheel package at Judgement Day in 3 weeks
thanks for all the input here and at home
Tex
7356312-IMG.pdf (230 downloads)
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Weight reduction showed up in new PB [Re: tex013] #1293894
08/29/12 08:00 PM
08/29/12 08:00 PM
fullmetaljacket Offline
What kind of car do you have?
Re: Weight reduction showed up in new PB [Re: fullmetaljacket] #1293895
08/29/12 08:13 PM
08/29/12 08:13 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
a 1968 Satellite
Tex
New best MPH 130.32
Re: Weight reduction showed up in new PB [Re: tex013] #1293896
08/29/12 09:10 PM
08/29/12 09:10 PM
Nice piece and it deserves to be on the lightweight side.
Got to love those light weight B-bodies.
Re: Weight reduction showed up in new PB [Re: fullmetaljacket] #1293897
08/29/12 09:23 PM
08/29/12 09:23 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
light weight
down here when i race bracket i am one of the heaviest,lots of 28-3400lb cars.
not much more i can lose.i have a glass bonnet and front bumper,ali heads waterpump and radiator.
i do have the stock bench in front plus heater/demister
Tex
New best MPH 130.32
Re: Weight reduction showed up in new PB [Re: tex013] #1293898
08/30/12 12:27 AM
08/30/12 12:27 AM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
Great job mate! I'm tippin my fosters to ya!
74 dart sport 440 www.Csucarbs.com
Re: Weight reduction showed up in new PB [Re: tex013] #1293899
08/30/12 01:07 AM
08/30/12 01:07 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
a 1968 Satellite
Tex
Might I say a rather nice looking 68 Satellite. Congrats on the new best Tex. Ron
Re: Weight reduction showed up in new PB [Re: 383man] #1293900
08/30/12 03:56 AM
08/30/12 03:56 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks for the kind words all.
still a little tinkering left.who knows
Tex
New best MPH 130.32
Re: Weight reduction showed up in new PB [Re: tex013] #1293901
08/30/12 04:50 AM
08/30/12 04:50 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
`You're very close to that 10 now, one right move on a good day and you might get it, or some small mods. Are you running the tunnel ram still ? if not try a 2" supersucker, that helped my car.
congrats on your pb, nice car.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Weight reduction showed up in new PB [Re: deaks] #1293902
08/30/12 06:47 PM
08/30/12 06:47 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Mick,
i am back to the M1 with 825 mighty demon,has a 1" open spacer.
After looking at a tunnel ram it seems a little too hard to get a M1 ram(shorter) plus the ability to get it under the scoop.Plus the cost of getting one down here to Aus . My engine shop /dyno have suggested going to a Victor 440 which has a longer runner.i have seen the comparison tests so there does seem to be something more there.
The indy modman is on the shelf till/if i build a bigger cube or higher revving motor.
Got to thank Mick Vescio Motor Body Works for the paint job
Tex
New best MPH 130.32
Re: Weight reduction showed up in new PB [Re: tex013] #1293903
08/30/12 07:33 PM
08/30/12 07:33 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I run the supersucker on top of a victor int, it sits quite high.
Mick
best 60ft 1.36
Re: Weight reduction showed up in new PB [Re: deaks] #1293904
08/30/12 08:15 PM
08/30/12 08:15 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Mick,
thanks.if i fit the victor i will run no spacer initially,iirc they are 1" taller tham a M1.
if i go ahead it has to be inside a week as i have a number of races coming up over the next 8 weeks
hey Shoebox - i have said before no one down here drinks Foster's,it's terrible
here's a shot from wednesday night
Tex
New best MPH 130.32
Re: Weight reduction showed up in new PB [Re: tex013] #1293905
08/30/12 11:58 PM
08/30/12 11:58 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Congrats and thanks for a good chuckle- I didn't know you aussies call windshield wipers a 'demister'!
Re: Weight reduction showed up in new PB [Re: tex013] #1293906
08/31/12 12:14 AM
08/31/12 12:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have always been in favor of making the car LITE
any way you can.... its easier on parts and you dont
need big power
Re: Weight reduction showed up in new PB [Re: radar] #1293907
08/31/12 12:33 AM
08/31/12 12:33 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Hey Radar,
i do have the heater demister unit under the dash works a treat in winter
Tex
New best MPH 130.32
