I have been chasing a little more et recently,to put me closer to the pointy end in my racing class.
After farting around with induction and cam etc i finally got down to the nitty gritty - weight.
2 weeks ago i got some new hoosiers(275/60R15) and whilst i was at i weighed up some wheels/tyre combos
Weld 15x8 with Hoosier 9.0x30R15 (lite weight) 14.6kg
Torquethrust 2 15x10 MT 295/65R15 25.75kg
Centreline Qualifier 15x8 Hoosier 275/60R15 17.3kg (38.06 lbs)
Centreline Qualifier 15x8 R/stone 255/70R15 21.9kg
Centreline Qualifier 15x4 H/cook 185/80R15 14.2kg
In for a penny in for a pound i thought weigh the rear seat,my mates keep saying pull it out it's dead weight . 20.29kg (44.74 lbs)
Maybe i should race with less uel in the tank,stock with sump.OK instead of starting with about 60 litres (15Gal) lets try around 30 litres,there's around 21kg (46lbs)
Went to the street meet last night.These have not much prep and around 180 cars run mostly street tyres.
For the time of year it was quite mild,high 60's low 70's temp.Using my predicter weather station it sat between 1345 and 1500DA all night.
Predicter called 11.15-17 all night.
1st pass - 1.542 sixty for a [Email]11.182@119.38[/Email] but good mph
2nd pass - 1.525 sixty for a [Email]11.109@119.80[/Email] thought the bonnet lifted a little high
3rd pass 1.517 sixty for a [Email]11.109@119.36[/Email]
PB in sixty footer
Full track oil down 50 minute clean up .Darn thought the track may go too cold
4th pass - 1.511 sixty for a [Email]11.084@119.69[/Email] PB in 60' and ET
The weight reduction was around 80 - 90 lbs to give an et reduction of 6 - 8 hundredths.
Well worth the effort.Unfortunately we are now moving out from the killer cold dry air into spring.Now to try the Hoosier lite weight 30x9 Weld wheel package at Judgement Day in 3 weeks
thanks for all the input here and at home
Tex
7356312-IMG.pdf (230 downloads)
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
