Re: Has anyone done this test with K&N air filters?
[Re: rjones]
#129367
09/29/08 11:33 AM
09/29/08 11:33 AM
Posts: 17,912 S.E. Michigan
ZIPPY
S.E. Michigan
Only time I did was with a buddy's car. 6-71 blown Pontiac 400, at that time it was making something like 660Hp at the wheels.
He had 2 1050 carbs and some small air cleaners, only 7x3. We pulled off the filter elements and it only picked up about 7hp with no filters at all. We thought that was pretty good considering the airflow requirements, and how small the filters were.
Rich H.
Esse Quam Videri
[Re: rjones]
#129369
09/29/08 12:58 PM
09/29/08 12:58 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
good reading here http://mymiata.paladinmicro.com/K&NComments.htmbest line in the artical is "Manufacturers spend vast amounts of money playing the horsepower game, while meeting CAFE requirements. If spending $20 more per vehicle would improve horsepower and efficiency they would do it--they have no motivation not to."
[Re: Mr.Yuck]
#129371
09/29/08 02:37 PM
09/29/08 02:37 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Interesting thread. There was a heated debate some time ago on one of the Cummin's diesel sites where arguably filtration is even more important due to high boost pressures and "dusting" of turbo blades, etc. and after much arguing there was a test done on a 400 + hp engine and the result of a K&N drop in vs. the stock paper was that there was zero difference in output.
That information coupled with reports of particulate on the turbo blades of trucks equipped with the K&N prompted me to remove mine and replace the factory filter. Some people swear by them and it seems to generate as much emotion as an oil thread.
YMMV
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: Mr.Yuck]
#129372
09/29/08 03:33 PM
09/29/08 03:33 PM
Posts: 1,396 Mass
dgc333
Mass
That quote was made by someone that does not understand how products are designed.
Adding $20 to the cost of each vehicle is a HUGE amount of money when you are talking about 100,000 or more units being made in the course of a year. That $2 million dollars would go right to the bottom line, so of course they have a motivation not to.
All manufacturers play the game of minimizing the cost while still meeting requirements automotive or otherwise. If an engineer can meet requirements with a less costly part he is not going to spec one that costs more even if it was better or he won't have a job for long.
So if the requirement is 300 HP or the MPG is 25 and those requirements can be met with a cheaper filter then that is what is used even though a more costly part may have given you 320 HP and 30 mpg.
Now for a personal experience. I used to race dirt bikes back in the 70's. They all came from the factory with a paper air filter back then. Quite often on a 100 mile eduro in dusty conditions I would have to stop and knock the dirt off the paper filter because it would be plugged to the point of impacting the engine. I would also find a fine coating of dust down stream from the filter after one of these type outings. When the oiled foam filters started becoming availble I switched. I never had a filter plug up on a ride after that and down stream I never had the fine layer of dust after the switch either.
[Re: dgc333]
#129374
09/29/08 04:09 PM
09/29/08 04:09 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
![](/ubbthreads/images/graemlins/iagree.gif) And as an engineer (or a knowledgable consumer) one might propose that the consumer would be willing to pay a few dollars more for a demonstratably-superior product, but the decision is still NO. The high-volume manufacturing world just does not work that way!
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: dgc333]
#129376
09/29/08 07:22 PM
09/29/08 07:22 PM
Mr.Yuck
Brookeville, Md
I think you are wrong if they could sqeak out an additional 2-3 mpg and pickup an extra 5-10 ponies they would spend the extra $20...not that it would cost them anything, that would be past to the customer. I've bought and been given K&N's for my vehicles. I saw zero perfomance gains and maybe had slighty worse milage. That said I do like the idea of the K&N flow-thru lid.
[Re: Mr.Yuck]
#129377
09/29/08 08:01 PM
09/29/08 08:01 PM
Posts: 1,396 Mass
dgc333
Mass
Having been an engineer for the past 30+ years, its always about the bucks. Reduced costs mean more profits or reduced sale price which means more market share and more profits.
Even changes to improve quality have to be justified with a cost savings (i.e., reduced scrap, rework, warranty claims, increased market share, etc).
The marketeers will define and justify horsepower and economy requirements and the engineers have to design to those goals at the lowest cost possible.
FWIW, I have since they became readily available back in the early 80's used an oiled foam or an oiled gauze filter in all my vehicles. Not because of a performance or economy improvement (but that is well come if its realized) but because its a great cost savings over the life of the car. I typically keep my daily drivers for 250,000 - 300,000 miles and an $8 filter every 10k miles adds up. Buy the K&N or other washable brand once for $40 and its paid for in the first 1 1/2 over ownership.
[Re: DPelletier]
#129378
09/29/08 08:20 PM
09/29/08 08:20 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
YMMV
I'd like to see that test as I did a test of my own and got completly different results , though not the exact same test .
My 2000 ram with a Cummins made 377hp at the rear wheels on 3 consecutive pulls , I was running the LONG K+N cone filter that was the rage then , I had borrwed it from a friend to test it before buying one. Later that evening I put my truck back on the dyno and ran it again but this time I was down 15hp, made a couple more pulls and couldn't figure out why. Suddenly I remember I put back the stock airbox with the stock paper filter, I popped open the top of the filter housing and propped it open with the paper filter, make another pull and my lost 15HP returned , pulled it off the dyno and proceeded to twist the output shaft off the end of the OD unit.
YMMV
[Re: rjones]
#129381
09/29/08 11:27 PM
09/29/08 11:27 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Theres no question that a K&N type filter will out-flow a paper element per square inch of material. The question is: how much flow is required by the engine and is there enough filter area to satisfy that need. If you are using a 3" tall x 14" diameter open element paper filter. You probobly have plenty of airflow capability to satisfy your motor. Adding a K&N would be pointless in most cases, It's like pouring 8 gallons of water into a 5 gallon bucket.
[Re: JohnRR]
#129382
09/29/08 11:38 PM
09/29/08 11:38 PM
Posts: 8,064 Arlington, Texas
earlybee
Arlington, Texas
Ever been to a concrete batch plant? Cement powder dust is around 1-3 microns. No where on the plant/property or in the mixer trucks or f/end loaders, are K-N filters used. They don,t work in this environment, only paper filters are used. K-N filters have to use oil to catch dust, and oil migrates with heat/gravity. Dry on top, wet on the bottom. The reason K-N flows almost as much air as no filter, is because its a bugcatcher, not a air filter. I rank K-N air filters right up there with Fram oil filters. Thats my ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: rjones]
#129384
09/30/08 09:20 AM
09/30/08 09:20 AM
JohnRR
Did you also have the airbox in place with the K&N filter? This could have had more to do with the increased power instead of the filter.
I have had some motorcycles that would respond with a substantial increase in power when the airbox is opened up.
Roger
No roger I didn't have the air box in place and I can't remember if this was before or after i added extra holes in the air box to get more air in it that the one hole the factory had .
your motorcycle tests tells me the air box is too small and causing a restriction in total airflow , packaing issue by the designers ...
I'm not saying that all the claims by K+N are true or false , just relating my story from what I actually did .
[Re: JohnRR]
#129385
09/30/08 10:54 AM
09/30/08 10:54 AM
DPelletier
YMMV
YMMV
Sorry John, that was a long time ago ( back then I spent more time on the TDR than I do on Moparts now! ) What I CAN tell you from memory is that the test I saw was for the drop-in replacement K&N vs. the stock set-up so I suspect your 15hp came from the removal of the airbox. ![](/ubbthreads/images/graemlins/shruggy.gif)
After spending significant time researching the subject and some very passionate arguments from both sides, I came away with the feeling that the K&N offers little to no performance advantage and that it likely has inferior filtration (especially on a turbocharged engine). Most of the other TDR members came to the same conclusion and went with what is now referred to as the BHAF (Big Honkin Air Filter) which is a large cylindrical paper filter.
People can run whatever they like, but at $10k a pop, I didn't feel like experimenting with my Cumminses. ![](/ubbthreads/images/graemlins/biggrin.gif)
![](/ubbthreads/images/graemlins/beer.gif) Dave
1974 'Cuda
