Park brake cable installation , Push button 727 valint #1292961
08/28/12 03:09 PM
08/28/12 03:09 PM
Glendale AZ
jimmyc340 Offline OP
Glendale AZ
I removed the old one and installed the new but it wont release so I cant put the car in gear. Any help will be appriciated
Ji
Re: Park brake cable installation , Push button 727 valint [Re: jimmyc340] #1292962
08/28/12 04:43 PM
08/28/12 04:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Did you make sure the cable was connected by pulling out gently on the cable housing?
To adjust the cable, place the Park lever in the OFF position and have somebody hold it there; then pull out gently on the cable housing to its limit of travel and then tighten the clamp stud nut to no more than 10 inch lbs.
Re: Park brake cable installation , Push button 727 valint [Re: John_Kunkel] #1292963
08/28/12 06:25 PM
08/28/12 06:25 PM
Glendale AZ
Glendale AZ
thank you very much
