Re: Anything to gain by porting Edelbrock RPM heads?
[Re: Cab_Burge]
#1292513
08/28/12 01:20 AM
08/28/12 01:20 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Some of the RPM castings OOTB are as poor as mid 260s. IIRC, modern can get 320ish out of em CNC'ed. That would make a monster difference on a 500 incher.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Kern Dog]
#1292515
08/28/12 01:36 AM
08/28/12 01:36 AM
Posts: 43,193 Bend,OR USA
Cab_Burge
Can someone elaborate a little about CNC porting? I seem to bypass most magazine articles on porting, but I seem to recall that it involves a computer programmed machine instead of porting by hand? If so, I suppose the advantage is a more consistant port size from cylinder to cylinder?
I think that all of the CNC programs are based on hand porting two cylinder ports, a left and right hand port(I hope that makes sense ) to get the optimum flow and then have the CNC probe measure and store all the numbers in its memory and make all the other ports match those two, one left hand and one right hand If I'm wrong I hope someone will correct me Jeff, Dan, Todd?
[Re: Kern Dog]
#1292516
08/28/12 03:04 AM
08/28/12 03:04 AM
DaytonaTurbo
Manitoba, Canada
Basically the machine does it. With the computer in control, results can be duplicated and guaranteed.
[Re: Jerry]
#1292521
08/28/12 12:33 PM
08/28/12 12:33 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
whats the next head up from the edelbrock. is it worth upgrading the heads instead of cnc porting?
I would think an Indy EZ
[Re: JohnRR]
#1292522
08/28/12 01:04 PM
08/28/12 01:04 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
A good Friend of mine is clicking off 8.90's in his duster with a set of ported edelbrock at 2500#. I should add that he did this the last few weeks in terrible air.
[Re: dogdays]
#1292523
08/28/12 05:00 PM
08/28/12 05:00 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
With the right cam and heads your 493 will make 600 hp, actually it shouldn't be hard. To get there you need around 300 cfm at 28" depression, the standard. You are at 260-270 now. an extra 30 cfm can mean more than 60 hp.
Think about it...if you built a stroker you must have wanted more power. Porting the heads is a proven way to get there, you would notice the difference with the cam you have now.
Going "the next step up" in an Edelbrock head puts you into the realm of offset rockers, more on the race side. I'd say don't do it unless you are a strictly quarter mile guy.
Jeff at Modern Cylinder heads seems to have the program for CNC porting these heads. As said above, a CNC program starts with an optimized port. It is then measured and the dimensions changed into directions for a computer numeric controlled milling machine. The machine does every port the same and it doesn't require a skilled individual to do it by hand. The net result is the best port for every cylinder. The hard part is getting the right port and making a program.
R. [/quoI agree 100% with Dog. Why bother stroking it then? Its a 493, let it breath.
Another example, such as Johns above, but totally different car, 3600# leaf spring foot brake bracket car, has gone 10.06 @132+, and goes and goes and goes. Not even really optimized, because its in bracket mode. Uses a shelf .650 Comp cam. Heads were 296@.550, 304 @ .600
The Eddy heads work very well. These heads were hand ported.Stuff it in the 2500# Duster below, and probably similar results, although I'd think the Duster has more lobe seperation and more lift, just guessing.
RIP Monte Smith
[Re: pittsburghracer]
#1292524
08/28/12 05:02 PM
08/28/12 05:02 PM
CompWedgeEngines
Syracuse,NY
Thats awesome John...did you do those heads? .700 ish lift? Electronics or Non Electronics car? How many CI" ?
RIP Monte Smith
[Re: Jerry]
#1292525
08/28/12 05:51 PM
08/28/12 05:51 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
It depends upon how far you want to go. If you already own the RPM head, it can be hand ported to make 787 HP on a 451ci all motor, pump gas engine. To get that much from another head, you have to get the new head AND have it ported.
If you are looking for beyond 700 HP you should start with something other than the RPM head. If you already own them, 750 HP isn't beyond their capability.
