Anything to gain by porting Edelbrock RPM heads? #1292507
08/27/12 11:31 PM
08/27/12 11:31 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I have a set of box stock Edelbrock RPM heads on my 440/493 and was curious about head porting. I have 10.8 compression, a 292/509 cam, RPM intake, 850 VS carb, 2" TTI headers and 2 1/2" exhaust.
I dont drag race the car, but might someday. I've considered swapping in a Comp Cams XE285 stick.
I've asked around about porting here in Sacramento but haven't had much luck. I would expect this service to be pricey and wonder if the juice is worth the squeeze.
Any thoughts?
Re: Anything to gain by porting Edelbrock RPM heads? [Re: Kern Dog] #1292508
08/28/12 12:23 AM
08/28/12 12:23 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yes there are gains to be had, around 30cfm on the intake side at .500-600 lift. You want to send them to someone who does CNC porting like jeff at modern cylinder head. I think the service costs a bit over 1k but the results are very nice. It's up to you if it's worth it.
Re: Anything to gain by porting Edelbrock RPM heads? [Re: DaytonaTurbo] #1292509
08/28/12 12:52 AM
08/28/12 12:52 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree definetly worth porting on a 493 eng. The CNC would be the way to go. Ron
Re: Anything to gain by porting Edelbrock RPM heads? [Re: DaytonaTurbo] #1292510
08/28/12 12:54 AM
08/28/12 12:54 AM
IN
ahy Offline
ahy  Offline
IN
Air flow creates power. 30 CFM at peak lift is about 10% increase. Power increase is less as most "breathing" is at partial lift. Maybe 10% peak airflow is worth 5% power increase. Is it worth it to you?
Re: Anything to gain by porting Edelbrock RPM heads? [Re: Kern Dog] #1292511
08/28/12 01:10 AM
08/28/12 01:10 AM
I had two sets of stock Eddy RPM heads flowed, I sent Jeff one set and he picked them up 32 CFM by using his CNC program on them, the reults where on the same flow bench by the same tech. at a machine shop I trust and use(Pettis Performance) They didn't have a interest or a dog in the fight in the results It is way better to have the flow(power available) and not need it than to not have enough flow(power) when you need or want it
Re: Anything to gain by porting Edelbrock RPM heads? [Re: Cab_Burge] #1292512
08/28/12 01:19 AM
08/28/12 01:19 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Stupid question.....
What are the drawbacks, if any? Does fuel economy suffer? I know... anyone running 493 cubes shouldn't care, but I'm just curious about all aspects.
Re: Anything to gain by porting Edelbrock RPM heads? [Re: Cab_Burge] #1292513
08/28/12 01:20 AM
08/28/12 01:20 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Some of the RPM castings OOTB are as poor as mid 260s. IIRC, modern can get 320ish out of em CNC'ed. That would make a monster difference on a 500 incher.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Anything to gain by porting Edelbrock RPM heads? [Re: Von] #1292514
08/28/12 01:27 AM
08/28/12 01:27 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Can someone elaborate a little about CNC porting? I seem to bypass most magazine articles on porting, but I seem to recall that it involves a computer programmed machine instead of porting by hand?
If so, I suppose the advantage is a more consistant port size from cylinder to cylinder?
Re: Anything to gain by porting Edelbrock RPM heads? [Re: Kern Dog] #1292515
08/28/12 01:36 AM
08/28/12 01:36 AM
I think that all of the CNC programs are based on hand porting two cylinder ports, a left and right hand port(I hope that makes sense ) to get the optimum flow and then have the CNC probe measure and store all the numbers in its memory and make all the other ports match those two, one left hand and one right hand If I'm wrong I hope someone will correct me Jeff, Dan, Todd?
Re: Anything to gain by porting Edelbrock RPM heads? [Re: Kern Dog] #1292516
08/28/12 03:04 AM
08/28/12 03:04 AM
Manitoba, Canada
Manitoba, Canada
Basically the machine does it. With the computer in control, results can be duplicated and guaranteed.
Re: Anything to gain by porting Edelbrock RPM heads? [Re: Kern Dog] #1292517
08/28/12 08:25 AM
08/28/12 08:25 AM
tboomer Online work
tboomer  Online Work
I see you are in Ca. You would be in good hands using this guy.
http://www.immengines.com/
Brian is a member here and really knows his stuff!
Re: Anything to gain by porting Edelbrock RPM heads? [Re: tboomer] #1292518
08/28/12 08:46 AM
08/28/12 08:46 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
whats the next head up from the edelbrock. is it worth upgrading the heads instead of cnc porting?
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Anything to gain by porting Edelbrock RPM heads? [Re: Jerry] #1292519
08/28/12 09:16 AM
08/28/12 09:16 AM
tboomer Online work
tboomer  Online Work
I have a pair of Victors that may go on my 512..
Re: Anything to gain by porting Edelbrock RPM heads? [Re: tboomer] #1292520
08/28/12 12:09 PM
08/28/12 12:09 PM
dogdays Offline
dogdays  Offline
With the right cam and heads your 493 will make 600 hp, actually it shouldn't be hard. To get there you need around 300 cfm at 28" depression, the standard. You are at 260-270 now. an extra 30 cfm can mean more than 60 hp.
Think about it...if you built a stroker you must have wanted more power. Porting the heads is a proven way to get there, you would notice the difference with the cam you have now.
Going "the next step up" in an Edelbrock head puts you into the realm of offset rockers, more on the race side. I'd say don't do it unless you are a strictly quarter mile guy.
Jeff at Modern Cylinder heads seems to have the program for CNC porting these heads. As said above, a CNC program starts with an optimized port. It is then measured and the dimensions changed into directions for a computer numeric controlled milling machine. The machine does every port the same and it doesn't require a skilled individual to do it by hand. The net result is the best port for every cylinder. The hard part is getting the right port and making a program.
R.
Re: Anything to gain by porting Edelbrock RPM heads? [Re: Jerry] #1292521
08/28/12 12:33 PM
08/28/12 12:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I would think an Indy EZ
Re: Anything to gain by porting Edelbrock RPM heads? [Re: JohnRR] #1292522
08/28/12 01:04 PM
08/28/12 01:04 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
A good Friend of mine is clicking off 8.90's in his duster with a set of ported edelbrock at 2500#. I should add that he did this the last few weeks in terrible air.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Anything to gain by porting Edelbrock RPM heads? [Re: dogdays] #1292523
08/28/12 05:00 PM
08/28/12 05:00 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
R. [/quoI agree 100% with Dog. Why bother stroking it then? Its a 493, let it breath.
Another example, such as Johns above, but totally different car, 3600# leaf spring foot brake bracket car, has gone 10.06 @132+, and goes and goes and goes. Not even really optimized, because its in bracket mode. Uses a shelf .650 Comp cam. Heads were 296@.550, 304 @ .600
The Eddy heads work very well. These heads were hand ported.Stuff it in the 2500# Duster below, and probably similar results, although I'd think the Duster has more lobe seperation and more lift, just guessing.
RIP Monte Smith
Re: Anything to gain by porting Edelbrock RPM heads? [Re: pittsburghracer] #1292524
08/28/12 05:02 PM
08/28/12 05:02 PM
Syracuse,NY
Syracuse,NY
Thats awesome John...did you do those heads? .700 ish lift? Electronics or Non Electronics car? How many CI" ?
RIP Monte Smith
Re: Anything to gain by porting Edelbrock RPM heads? [Re: Jerry] #1292525
08/28/12 05:51 PM
08/28/12 05:51 PM
Idaho
LaRoy Engines Offline
Idaho
It depends upon how far you want to go. If you already own the RPM head, it can be hand ported to make 787 HP on a 451ci all motor, pump gas engine. To get that much from another head, you have to get the new head AND have it ported.
If you are looking for beyond 700 HP you should start with something other than the RPM head. If you already own them, 750 HP isn't beyond their capability.
Re: Anything to gain by porting Edelbrock RPM heads? [Re: CompWedgeEngines] #1292526
08/28/12 06:28 PM
08/28/12 06:28 PM
PA.
"Little"John
"Little"John
PA.
Tom Hemphill from Clarksburg, Pa. either did the heads for him or guided him through the process. He runs in the Top Class (electronics) and Todd I am not really sure about engine specs but I know its a stock block. His Dad runs the "Tim's Toy" 68 Charger. I know Tim has clicked off some 8.60's with an Indy block and a set of B1BS heads that Tom did for him.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
