Help decode trans #'s on 833
#1292412
08/27/12 09:17 PM
08/27/12 09:17 PM
Posts: 6,480 Kingston, IL USA!
gts340swinger
Kingston, IL USA!
I found this transmission this weekend. I understand the VIN portion but what do the other stampings mean?
If anyone has this car or knows of it, let me know.
Mr. Norm's "Fanatic" (idiot) 71 Mr. Norm's Demon GSS 77 Mr. Norm's personal B250 GSS van 76 Mr. Norm's KZ900 Motor Sports Special 69 Mr. Norm's M code Dart GTS 69 D100 68 Barracuda 64 Valiant V200 07 Charger Daytona SST 6 speed test mule.
Re: Help decode trans #'s on 833
[Re: gts340swinger]
#1292413
08/27/12 09:36 PM
08/27/12 09:36 PM
gts340swinger
Kingston, IL USA!
PP833 3057 159 are the other, smaller numbers.
[Re: 6bblgt]
#1292416
08/28/12 10:07 AM
08/28/12 10:07 AM
gts340swinger
Kingston, IL USA!
This is an 18 Spline out of a 70 Charger R/T. Not sure what happened to the car but the same guy might have the original 440 block out of it also that matches the trans.
Thanks for the reply guys.
[Re: 6bblgt]
#1292417
08/28/12 10:11 AM
08/28/12 10:11 AM
gts340swinger
Kingston, IL USA!
One more question. This transmission has dual shifter mounting locations on it (70 E-body, 71-up B-body) and I thought a 70 correct trans would only have one. Does this seem right? It has an aftermarket steel bellhousing and B&M shifter right now. It has also been painted red so anything is possible.
[Re: JohnRR]
#1292419
08/28/12 10:35 AM
08/28/12 10:35 AM
gts340swinger
Kingston, IL USA!
OK, good to know. I guess it makes sense since the E-bodies used them in 70.
