Help decode trans #'s on 833 #1292412
08/27/12 09:17 PM
08/27/12 09:17 PM
Kingston, IL USA!
gts340swinger Offline OP
Kingston, IL USA!
I found this transmission this weekend. I understand the VIN portion but what do the other stampings mean?
If anyone has this car or knows of it, let me know.
Mr. Norm's "Fanatic" (idiot)
71 Mr. Norm's Demon GSS
77 Mr. Norm's personal B250 GSS van
76 Mr. Norm's KZ900 Motor Sports Special
69 Mr. Norm's M code Dart GTS
69 D100
68 Barracuda
64 Valiant V200
07 Charger Daytona SST 6 speed test mule.
Re: Help decode trans #'s on 833 [Re: gts340swinger] #1292413
08/27/12 09:36 PM
08/27/12 09:36 PM
Kingston, IL USA!
Kingston, IL USA!
PP833 3057 159 are the other, smaller numbers.
69 D100
68 Barracuda
64 Valiant V200
Re: Help decode trans #'s on 833 [Re: gts340swinger] #1292414
08/27/12 10:47 PM
08/27/12 10:47 PM
Minnesota USA
Dart6pak Offline
Dart6pak  Offline
Minnesota USA
0---1970
G---St Louis
174793---last 6 digits of the vin #
3057--Installed Dec 10,1969
159---sequence # of trans built
Re: Help decode trans #'s on 833 [Re: Dart6pak] #1292415
08/27/12 11:57 PM
08/27/12 11:57 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Transmission is from a Charger - is it 18 or 23-spline?
0---1970
G---St Louis
3057-- transmission assembled Wednesday, Dec 10,1969
Re: Help decode trans #'s on 833 [Re: 6bblgt] #1292416
08/28/12 10:07 AM
08/28/12 10:07 AM
Kingston, IL USA!
Kingston, IL USA!
This is an 18 Spline out of a 70 Charger R/T. Not sure what happened to the car but the same guy might have the original 440 block out of it also that matches the trans.
Thanks for the reply guys.
69 D100
68 Barracuda
64 Valiant V200
Re: Help decode trans #'s on 833 [Re: 6bblgt] #1292417
08/28/12 10:11 AM
08/28/12 10:11 AM
Kingston, IL USA!
Kingston, IL USA!
One more question. This transmission has dual shifter mounting locations on it (70 E-body, 71-up B-body) and I thought a 70 correct trans would only have one. Does this seem right? It has an aftermarket steel bellhousing and B&M shifter right now. It has also been painted red so anything is possible.
69 D100
68 Barracuda
64 Valiant V200
Re: Help decode trans #'s on 833 [Re: gts340swinger] #1292418
08/28/12 10:14 AM
08/28/12 10:14 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Staring with the 70 model year the tailshaft had both mounting pads, a 71-74 B body with a buddy seat would use the forward mount .
Re: Help decode trans #'s on 833 [Re: JohnRR] #1292419
08/28/12 10:35 AM
08/28/12 10:35 AM
Kingston, IL USA!
Kingston, IL USA!
OK, good to know. I guess it makes sense since the E-bodies used them in 70.
69 D100
68 Barracuda
64 Valiant V200
