valve body question #128792
09/27/08 09:49 PM
09/27/08 09:49 PM
wine valley
cudaben1968 Offline OP
wine valley
would a valve body from a 65 727 in a 68 727 have any problems? i know the 66-7? is the same but what would happen with a pre 66? I hada 65 one in mine and the trans had no reverse or high gear, i pulled the valve body and did the press. tests and all worked right... could it be my valve body? I have a aftermakret one i think its turbo action i bought like 2 years ago for a 66 up style, just wondering if that could be my problem
Half measures availed us nothing. We stood at the turning point. -Alcoholics Anonymous, The Big Book
Re: valve body question [Re: cudaben1968] #128793
09/28/08 03:38 AM
09/28/08 03:38 AM
wine valley
wine valley
nobody knows about transmission valve bodies???
Re: valve body question [Re: cudaben1968] #128794
09/28/08 03:54 AM
09/28/08 03:54 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
65 is cable shift...
Re: valve body question [Re: cudaben1968] #128795
09/28/08 04:07 AM
09/28/08 04:07 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I know there are about 10 different types of Valves bodies for the 727. I would double check tat all the prts line up with your transmission. It could be very likely your valve body is the problem. I know that A&A make one specifically for the earlier style.
AL...
Alan Jones
Re: valve body question [Re: LA360] #128796
09/28/08 04:30 AM
09/28/08 04:30 AM
wine valley
wine valley
i know 65 would be cable shift but irt isnt, it may just be a 65 tail housing it has the different trans mount and when i talked to schumacher he told me it was 65 style...
Re: valve body question [Re: cudaben1968] #128797
09/28/08 08:11 AM
09/28/08 08:11 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
do you have the stamped number's off the side of the pan rail? that will indicate the year and application of the trans, also the valvebody will have a cast number inside a little sunburst, that should indicate the year of mfg.
I was thinking that from 66 to 72 was interchangeable and 72 up to ?? was interchangable,,but I may be thinking 904's, hope this help's.
Re: valve body question [Re: cudaben1968] #128798
09/28/08 10:56 AM
09/28/08 10:56 AM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
As my past experience you can not use a65 valvebody in a late model case the rooster comb is different , plus you already know it a cable shift , now you can interchange parts like valves and upper half but thats about it imo
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: valve body question [Re: cudaben1968] #128799
09/28/08 03:25 PM
09/28/08 03:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you're using casting dates on the VB castings to determine the year, many '66 VB's will have '65 casting dates as will the other transmission components. There is no way a '65 VB will physically work in a '66 trans.
A '66 VB will work in a '68, if there is no Reverse or 3rd there is a problem with the front clutch.
Re: valve body question [Re: John_Kunkel] #128800
09/28/08 08:51 PM
09/28/08 08:51 PM
wine valley
wine valley
ok so if i do the pressure tests and the front clutch moves freely everytime then what? I had a little reverse movement for a mintue then it stopped... rear band???
Re: valve body question [Re: cudaben1968] #128801
09/29/08 03:49 PM
09/29/08 03:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If Reverse and 3rd are missing the problem is in the front clutch, the air check can be deceiving. The line pressure in Reverse is 3-4 times higher than in the forward gears so a faulty clutch can partly engage in Reverse but not 3rd.
