valve body question
#128792
09/27/08 09:49 PM
09/27/08 09:49 PM
Posts: 388 wine valley
cudaben1968
wine valley
would a valve body from a 65 727 in a 68 727 have any problems? i know the 66-7? is the same but what would happen with a pre 66? I hada 65 one in mine and the trans had no reverse or high gear, i pulled the valve body and did the press. tests and all worked right... could it be my valve body? I have a aftermakret one i think its turbo action i bought like 2 years ago for a 66 up style, just wondering if that could be my problem
Half measures availed us nothing. We stood at the turning point.
-Alcoholics Anonymous, The Big Book
Re: valve body question
[Re: cudaben1968]
#128793
09/28/08 03:38 AM
09/28/08 03:38 AM
cudaben1968
wine valley
nobody knows about transmission valve bodies???
[Re: cudaben1968]
#128795
09/28/08 04:07 AM
09/28/08 04:07 AM
Posts: 6,142 Melbourne , Australia
LA360
I know there are about 10 different types of Valves bodies for the 727. I would double check tat all the prts line up with your transmission. It could be very likely your valve body is the problem. I know that A&A make one specifically for the earlier style. AL...
Alan Jones
[Re: LA360]
#128796
09/28/08 04:30 AM
09/28/08 04:30 AM
cudaben1968
wine valley
i know 65 would be cable shift but irt isnt, it may just be a 65 tail housing it has the different trans mount and when i talked to schumacher he told me it was 65 style...
[Re: cudaben1968]
#128797
09/28/08 08:11 AM
09/28/08 08:11 AM
dartman366
Mt. Vernon, Ohio
do you have the stamped number's off the side of the pan rail? that will indicate the year and application of the trans, also the valvebody will have a cast number inside a little sunburst, that should indicate the year of mfg. I was thinking that from 66 to 72 was interchangeable and 72 up to ?? was interchangable,,but I may be thinking 904's, hope this help's.
[Re: cudaben1968]
#128799
09/28/08 03:25 PM
09/28/08 03:25 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you're using casting dates on the VB castings to determine the year, many '66 VB's will have '65 casting dates as will the other transmission components. There is no way a '65 VB will physically work in a '66 trans.
A '66 VB will work in a '68, if there is no Reverse or 3rd there is a problem with the front clutch.
[Re: John_Kunkel]
#128800
09/28/08 08:51 PM
09/28/08 08:51 PM
cudaben1968
wine valley
ok so if i do the pressure tests and the front clutch moves freely everytime then what? I had a little reverse movement for a mintue then it stopped... rear band???
[Re: cudaben1968]
#128801
09/29/08 03:49 PM
09/29/08 03:49 PM
John_Kunkel
Rio Linda, CA
If Reverse and 3rd are missing the problem is in the front clutch, the air check can be deceiving. The line pressure in Reverse is 3-4 times higher than in the forward gears so a faulty clutch can partly engage in Reverse but not 3rd.
